Ring & Pinion and Misc Damage to Trans
Ok,
I thought I share this interesting YouTube link that highlights the possible damage when one form of the trannie 'ring & pinion" is improperly set up (oh, I will just eye ball it solution)...let’s say it most likely was not fully measured on the specs. Combine that with high HP one ends up with a mess.
I'm sure glad that's not my trannie that will need a lot of help & $$$
What can happen is if you slide the car sideways and impact the wheel it can destroy wheel bearings. If the hit is hard enough it forces the driveshaft inward and can destroy differential bearings too.
Incorrect differential shimming manifests itself with noises first usually.
i'm told thatwhile the bearings are heat cycle sensitive it was that hard lateral force that exterted undue stress, resulting in bearing failure. they can only take so much ( at 111k miles, some tracking ), and are partially "sealed" which allows them to dry out..heat cycles again...
ModBargains
Lotus Vendor Classifieds
10-13-2015 03:42 PM
ModBargains
McLaren Vendor Classifieds
10-13-2015 03:41 PM
ModBargains
10-13-2015 03:40 PM
The Youngn
09-10-2015 12:24 PM
