TT Running too rich?
I was out cleaning the TT today. I noticed that there was a lot of carbon deposit on in the tail pipes. I'm assuming this mean it is running rich.
Where should I troubleshoot first? Will this harm the car running it like this?
You will always have carbon buildup in the tailpipes and it does not means you are running any richer than you should be. If you have other symptoms such as smoke, hard warm engine starts, etc, then go looking for trouble. Otherwise, drive and enjoy.
Re: TT Running too rich?
Do you have a stock or modified/aftermarket exhaust?
Very good to know that it runs rich by design. I don't have any other problems and I guess I was worrying for nothing.
I have a stock exhaust.
There are a few drawbacks to running rich:
1. You won't get the maximum performance that you would get with a perfectly balanced air/fuel ratio given the engine load/rpm/etc. However, walking that line is dangerous as knock is a fine line at times. I'd rather run slightly rich than walk the fine line of perfectly mixed vs barely lean.
2. Your plugs will "foul" sooner. Much like running more lean (turns the plugs white), running rich will "darken" your plugs. Then again, replacing plugs are an easier/cheaper solution than replacing a piston.
Porsche turbos (as well as most turbos sold by manufacturers) run "slightly" rich.
A friend of mine tuned his BPU supra (mostly stock) and realized a 10% HP gain at the wheels. He went from 360 to 395.
His fuel curve went down from 12.5:1 to about 11:5:1. Still a pretty conservative setting.
