Still issue with 996tt after 3 months
Old 04-14-2014 | 08:22 AM
niceguy's Avatar
niceguy is infamous around these parts
I am very sad that I still cannot get this problem sorted after a few months. The new MAF 996.606.124.00 I bought from dealer was scratched on the metal film. Faulty MAF pics attached. Now back to the old MAF 5+ yrs old
Repairs done
Throttle body cleaned
Replaced vaccum hoses on top of DVs, metal Y-pipe, the stock solenoid.
New stock spark plugs
Replaced the 4 turbo and intercooler hoses (car reaches target boost, no power loss at all)
Stock hollow wheels n tires
Symptoms
1. Abs/psm ONLY comes on whenever there is a small bump, read with durametric, P0102 Hot film
2. Engine rev dropping below 800rpm @ idle (tuner states it should be 800rpm steady) 3. Above 70kph (~44mph) the abs/psm NEVER comes on.
4. Clear code with durametric, P0102 always comes back.
To sum up the symptom, the car drives perfectly as long as there is some throttle or at WOT. There is no boost leak or power loss. It sits at 1.1 bar at peak boost and no CEL or any irregularities. Problem only takes place during town driving.
Possible issues
1. MAF
2. vacuum leak on the intake side
3 …
Can the car possibily have any other possible issue?
Old 04-14-2014 | 10:41 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
The one thing you forgot to replace is the MAF sensor lol. Order it at autoatlanta.com for 200.00 bucks and way you go. Hot film = MAF Sensor............
Old 04-14-2014 | 11:32 AM
niceguy's Avatar
I bought one from a local bosch authorized dealer but it was faulty. so now i really want to make sure i could solve the issue before i go out to buy another one.
Old 04-14-2014 | 11:34 AM
996tt550hp's Avatar
Originally Posted by niceguy
I bought one from a local bosch authorizes dealer but it was faulty. so now i really want to make sure i could solve the issue before i go out to buy another one.
Hot film means your maf is bad.
Old 04-14-2014 | 11:39 AM
'02996ttx50's Avatar
agreed. dollars to doughnuts you have a faulty maf. replace with a new bosch. part 124. should do it. if not? well, you needed one anyway.
Old 04-14-2014 | 11:49 AM
rmc1148's Avatar
Agreed get a new MAF.
Old 04-14-2014 | 12:33 PM
zmt's Avatar
zmt
zmt is infamous around these parts
make sure you try literally everything else before the MAF. Hot Film = make a sexy movie about how you changed everything in the car except the Mass Air Flow sensor.
Old 04-14-2014 | 01:05 PM
niceguy's Avatar
Thanks for all the replies, really appreciated
To sum up the issue, as long as the engine rev is above 2000rpm or provided that I have some throttle input, no abs/psm light will ever come on even when the car hits a bump. The car drives perfectly only has the annoying abs/psm issue during idling and city driving. I datalog some normal driving and 3rd &4th gear pulls and my tuner thinks they are absolutely fine. Does this suggest it is some kind of boost leak on the intake side?
Old 04-14-2014 | 01:16 PM
Tim941NYC's Avatar
Smoke test the car. remove the air box and smoke it through the intake. Use the tube the airbox was attached to.
Old 04-14-2014 | 01:36 PM
996tt550hp's Avatar
Do a search on MAF sensors thats what happens when its bad. Abs/Psm come on most of the time when your MAF sensor is bad.
To test unplug the MAF sensor and drive it to see if it cures. If it does then there you go.
Old 04-14-2014 | 02:41 PM
niceguy's Avatar
Assuming everything else is fine, if I pull the MAF, will the car run normal without the abs/psm? Is it not advised to test run the car with boost while the MAF connector is unplugged?
Old 04-14-2014 | 02:44 PM
996tt550hp's Avatar
Dont worry you will get a psm/abs code but your hesitarion and hot film will not come back. Just order a new maf i had the samething happen to me and it was fixed. Cleaning it will not help because its already fried so go to autoatlanta or call them its 200.00 bucks.
Old 04-14-2014 | 02:50 PM
niceguy's Avatar
I will report back after I pulled the MAF. thanks again for the help.
Old 04-14-2014 | 05:42 PM
Fasoole's Avatar
Fasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant future
I think you may check plug under steering wheel it's brake plug or something, i had this issue before and it wad pain in A$$ to figure it.
Old 04-15-2014 | 06:02 AM
niceguy's Avatar
Fasoole, thank you for your reply. If I see no flickering or irregularity with all 3 brake lights and that the abs/psm never comes on during braking. Can I rule out the issue with the brake plug?
Thanks again
Quick Reply: Still issue with 996tt after 3 months
