Which bleeder valve should be bled first Inner or Outer?
Hello,
I have done a search and have seen some people doing a brake bleed by bleeding the outer bleeder valve first and then the inner.
Can someone please tell me the correct way. Is it the outer first or the Inner?
Thanks in advance,
Al Z
Thanks in advance,
Al Z
bleed from the rear passenger caliper then d/s rear then pass from then drivers front. uouter bleeder then inner on pass then outer and inner on d/s your bleeding from the farthest point to the closest to the reservoir
motive power bleeder makes the job ez peazy
However the repair manual states no particular order or sequence. It just says make sure to do each caliper.
ECS Tuning - BMW
09-11-2015 09:02 AM
ECS Tuning - VW
09-08-2015 12:54 PM
