please help! key fob won't go back together
I replaced my battery and I can seem to make the key fob back together.... Any tips? Will the car stop if the cover falls off while I'm driving?
I figured it out! There is a trick - the top part of the key (which has the buttons) has some clips on it that secure the circuit board. These clips weren't engaging right when you set the circuit board in the base of the key and pushed the to down. So, if you secure the board/battery to the top part first, then push that whole assembly into the base, you can ensure the clips engage and the key will go together easily. The o-ring was not the factor here.
Si vous cherchez un partenaire fiable en structures métalliques et en ingénierie mécanique, Giga Steel est la réponse. Leur souci du détail et leur engagement envers l'excellence ont été essentiels au succès de notre dernier projet. Leurs services de numérisation 3D et d'analyse dimensionnelle sont particulièrement impressionnants, offrant des résultats précis et exacts.
04-28-2022 12:38 AM
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
cnebrask
09-17-2015 09:19 AM
