Fitted H&R Springs...Car has loads of bump steer now! Pls Help
Old 05-26-2014 | 06:13 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
I agree with the above that you do not need to buy dog ones, or sways or any other crap. Been down this road recently. Get an alignment and set the rear tires to +20-25 toe with as little as camber as possible. Toe makes these cars feel like ****, handle like a junker and destroy tires. A simple alignment makes life better
Old 05-26-2014 | 06:32 PM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
1st things first. After the springs did you get an alignment? What was it set to?
Old 05-27-2014 | 03:25 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Originally Posted by born2boost
Hi Guys
I have recently fitted H&R Springs to my 996tt. The car feels horrible now. Its very unstable at high speed and my rear tires are wearing badly on the inside.
Any advice on which bump steer correction kit to get??
Any advice at all will be greatly appreciated
Thx!
Toe arms with bump steer correction, and everything else you'd need, from Europe:
http://www.9products.com/996997/products
Old 05-28-2014 | 04:46 AM
born2boost's Avatar
born2boost is infamous around these parts
Wow thanks for all the help and info guys!
I will definitely look into getting the proper parts to sort the problem out asap.
Interesting though...I looked at the spec sheet of the last wheel alignment done and everything except for the rear camber is within spec! Including the Toe??
Old 05-28-2014 | 06:49 AM
VGLNTE1's Avatar
I aligned to spec as well and ate a new set of tires in 3000 miles and the car felt horrible. Trust me. +.25 toe each side on rear.
Old 05-28-2014 | 08:57 AM
born2boost's Avatar
Thanks for the info! Do you mean .25 INCHES Positive Toe (Inward) ?
Old 05-28-2014 | 01:34 PM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
@ VGLNTE1, stock spec with +.25 toe out each side?
Old 05-28-2014 | 02:10 PM
VGLNTE1's Avatar
.25 each side. So .50 total Positive. Iwas going through tire after tire and a member here contacted me and he was nice enough to talk to me on the phone for a while. These cars squat so hard and with all that weight the wheels just toe out and go negative and eat them. Adding a bunch of positive will set them straight when under load. I have 3 times the miles on mine now and show perfect wear and it handles so much better.
Old 05-28-2014 | 02:11 PM
VGLNTE1's Avatar
Degrees
Old 05-28-2014 | 02:13 PM
VGLNTE1's Avatar
The member who helped me was "engine guy". Very helpful
Old 05-28-2014 | 03:46 PM
'02996ttx50's Avatar
don't try to re-invent the wheel alignment here lol
the spec sets from the factory that should help for your lowered car are ROW TURBO spec or GT2/ X73: if i'm not mistaken, the ROW spec for 96turbo is a bit lower in height than US model. below is the x73 set similar to the gt2 set. it'll help. along with all the other suggestions of course. you'll have to decipher all the #'s with the tech but it's pretty straightforward stuff. alternately most/all alignment computers have the gt2/X73 alignments specs in their database. ask there and begin with those. NOT the "stock" numbers. i stand by my earlier suggestion(s),.. and good luck.
X73 alignment specifications. similar to gt2(?) or use those as well.
these *should* be accurate and there are numerous threads here, wherein i found these numbers. search if you need more.
ps. many say zero toe front. a smidgen lol.. rear.
FRONT:
Front Toe Unpressed (total) = +5' +/- 5'
Toe difference angle @ 20D lock = -1D50' +/- 30'
Camber = -45' +/- 15' with a max difference left to right of 20'
Caster = 8D +/- 30' with a max difference left to right of 40'
REAR:
Rear toe per wheel = +10' +/- 5' with a max difference left to right of 10'
Camber = -1D40' +/- 15' with a max difference left to right of 15'
Old 05-28-2014 | 08:15 PM
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
FRONT:
REAR:
Great info, thanks for sharing.
Would you recommend this for standard suspension, I have a 996TT 2003.
Old 05-28-2014 | 09:12 PM
i'm out of my depth on the topic as to what's *best*? so all i can add at this point, ( i'm not in any way particularly knowledgeable on the topic, so i only know from my cars ) but for a lowered car, the x73/gt2 alignment specs as written from porsche are as good a baseline as one can get. there are a myriad number of ways to fine tune from there, depending upon driving style, conditions, and what best suits the driver. but for most +/- 40mm or 1.5-2 inch drops? the gt2/x73 #'s will work perfectly.
there is little doubt though, that a lowered car that has not been aligned to compensate, will not handle optimally at all, and will exponentially increase its appetite for rubber lol
Old 05-29-2014 | 01:48 PM
VGLNTE1's Avatar
FRONT:
REAR:
I ran to spec. Trashed tires and still felt horrible
Old 05-29-2014 | 01:50 PM
VGLNTE1's Avatar
I am by no means an expert, but engine guy seemed to be. Maybe send him a pm and he can give some advice
Quick Reply: Fitted H&R Springs...Car has loads of bump steer now! Pls Help
