Sparco Helmet and R3 Head and Neck Restraint Question
Old 09-19-2005 | 11:14 PM
KPV's Avatar
KPV
Hi Guys,
I am purchasing the R3 Head and Neck restraint
and I am slo picking up a new helmet to drill for this device. I was looking at the Bell M3 and the Simpson SPeedway Rx, but I stumbled across a, presumably, better option.....the Sparco WTT-TK-Helmet.
From OG Racing's website:
  • The WTT-TK is designed with a wide eye port for the sedan and touring car racer. The TK has extra ventilation designed into the front chin bar for improved ventilation when used in a closed cockpit. The TK comes with removable cheek padding so the driver can order different pads to achieve the desired fit. The TK also includes a 3mm homologated shield with CNC machined aluminum hardware, positive lock down hinge and lightweight adjustable air ducts.
    Features
  • Shell Properties: 100% Fiberglass construction offers optimum strength to weight characteristics. Sparco's Vacuum Form Resin Strengthening Process removes air during curing, ensuring a void free laminate. Proprietary Robotic Resin Thickness Control combined with a computerized measuring process ensures zero variance between helmets and precise weight uniformity. Precision Robotic Hydro-Jet Cutting Process for all helmet openings eliminates material fatigue which preserves laminate integrity.
  • Ventilation Characteristics: Proprietary Sparco AeroFlow channeling system provides optimal ventilation and air flow throughout the helmet in the most demanding environmental conditions. The WTT System consists of 4 Naca-shaped inlet slots on the chin bar; 3 reversible inlet/outlet air vents on the crown; 2 multipurpose exhaust/communication ports.
  • Shield Technology: Crystal clear un-obscured vision means better control and comfort. Optically correct, polycarbonate pre-formed 3 mm anti-scratch shield.
  • Aerodynamics: Revolutionary shape virtually elimates turbulence or buffeting.
  • Advanced Ergonomics: The SurroundSoft comfort system utilizes the optimum density of foam in each area of the helmet ensuring a proper fit and maximum comfort. An ultra-soft knit Nomex lining is used throughout. The inner liner is completely removable for easy cleaning and service.
  • HANS Device Compatible: A specially engineered platform eases the installation of HANS Devices.
The most important spec is the fact that there isn't some bogus disclaimer about drilling the helmet!! Instead, SParco recognizes the use of head and neck restraints and has specifically designed the helmet for a Hans device. Since the R3 utlizes the same concept, is it a fair statement that this helmet is a good choice for use with the R3??
Does anyone have this helmet and if so, how do you like it?
Old 09-24-2005 | 01:27 PM
KPV's Avatar
KPV
Well, I pulled the trigger on the helmet.
Old 09-24-2005 | 01:40 PM
ColorChange's Avatar
ColorChange is infamous around these parts
Kewl!
I may get a new hat soon but am waiting for the '05 Specs.
Old 09-24-2005 | 05:01 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
What's with the roll eyes ?
Nothing but the best for that large brain of yours !
Congrats. Hopefully we won't put them to the test at Watkin's...
Old 09-24-2005 | 05:03 PM
rockitman's Avatar
Re: Sparco Helmet and R3 Head and Neck Restraint Question
I have thought about this and it is of my opinion that the post positions for the Hans or the R3 is the same. I think the R3 uses simple d-rings attached to the helmet.
Old 09-25-2005 | 11:14 AM
03-turbo911's Avatar
Senior Member
Do you need a HANS specific seat harness if you want to wear this helmet and this R3 device?
Old 09-25-2005 | 11:26 AM
KPV's Avatar
KPV
Khalid,
No. The beauty of the R3 is that it can be used in ANY car. It becomes part of you in a sense. It goes where you go.
Old 09-25-2005 | 11:37 AM
Senior Member
Good to hear that Ken. I've been thinking of getting a new car racing helmet instead of my usual bike helmet. I'll keep this setup in mind when I do pull the trigger.
04-28-2022 01:38 AM
nlakind
11-06-2015 11:15 AM
turbotuner20v
09-11-2015 01:02 PM
TrackOne
08-20-2015 01:56 PM
