HRE wheels making clicking/ticking sound.
Old 06-17-2014, 10:33 AM
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
Glad you got it sorted and that it was something easy as that. Those nuisance issues can be a real pain to track and costly to fix.
-V
Old 06-17-2014, 01:32 PM
AdamNoone's Avatar
AdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant future
-V
Thanks V, sometimes I'd rather have a wheel fall off! That's an easy one to diagnose.
Old 06-17-2014, 01:53 PM
wross996TT's Avatar
I hate to be a stikler, but in order to say you actually know why it happened, you would need to be able to re-produce the clicking. Otherwise it could just be due to dis-assembly and re-assembly (or some other factor that changed at the same time)....just basic failure analysis FWIW.
Old 06-17-2014, 02:01 PM
AdamNoone's Avatar
I had removed the wheels and re-installed them multiple times to see if different lugs, torque patterns, anti-seize, etc would stop the clicking. After this removal, I torqued all 156 wheel bolts to matching specs, and now the clicking is gone. I am fairly confident with my conclusion. Right or wrong, the clicking is gone, and I am a happy camper.
Old 06-17-2014, 04:43 PM
32krazy!'s Avatar
shouldn't your question be WHY did the bolts come loose? aren't they one time use bolts? was there a vibration that caused them to loosen? was it all 4 wheels or just 1 wheel causing the sound? you may have a recurring issue your going to have to deal with
Old 06-18-2014, 12:37 AM
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
^this. Usually the bolts are secured with Loctite.
If this is a 3 piece wheel: if the inner and outer dish have moved I would also check tire pressure more often, because the seal could have become leaky.
Old 06-19-2014, 06:45 AM
Steve B.'s Avatar
Steve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to behold
Originally Posted by AdamNoone
Problem solved. Wheels are installed and the clicking is gone. Cause was improper torque on wheel bolts.
Thanks for the input, everyone!
I have the 542Rs... what is the correct torque for the bolts? Maybe I should check them regularly as a preventative measure.
Thanks!
Old 06-19-2014, 08:24 AM
AdamNoone's Avatar
Thanks!
Hey Steve,
The proper torque is 22 ft/lbs. Just make sure you have an accurate torque wrench.
Old 06-19-2014, 10:47 AM
Steve B.'s Avatar
Thank you Adam!
MrMiggy
08-21-2015 06:55 PM
08-21-2015 09:56 AM
ModBargains
08-20-2015 12:28 PM
Quick Reply: HRE wheels making clicking/ticking sound.
