O2 Codes After Exhaust - P1144 P1145
Hi everyone,
I put in a speedtech exhaust with 200cell cat. After a 100 miles or so, I got a CEL while light city driving. Bought a prometric and see P1144 and P1145 codes.
After some searching it seems a # of things can be occurring:
thanks.
Scott
- backwards reinstall- which sensor is precat and which is post. I see another post about grey/black wires but also "color coded"...
- O2 sensors are bad- any way to test via durametric?
- MAF- i pulled it out to clean it prior to exhaust install after hesitations as noted in other threads. Seems to run better- no codes other than 1144/1145.
- Bad lifters- seems to be other problem...hopefully not the case.
thanks.
Scott
Scott,
We have not produced exhausts with 200 cell cats for quite some time other than a couple of special requests on our X-cellerator system. You must have purchased our older generation twin can system, however, either way, I do not believe the codes are exhaust related.
My guess is the Bank 1 02 sensor before the exhaust may have become damaged during the installation - that code points to a precat 02 sensor problem with heating, which means it's not working properly or it points to an MAF issue, too.
My advice is to switch the primary 02 sensors from one side to the other and clear the code. If it comes back as bank 2, then it's the 02 sensor...
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Scott,
Hi John- i think I mispoke- looks like I picked up 100 cells. Just got around to installing it.
https://www.6speedonline.com/forums/...ross-flow.html
Thanks for suggestion I will give it a go this weekend.
Scott
Scott
Hi everyone,
thanks.
Scott
thanks.
Scott
It's not the lack of cats. I ran an ebwerks before this, also with cat bypass pipes, and never received any CEL. The secondary O2's are installed with bung extenders and even if they were the problem that is a different code.
Are you catless swappable ? I've had issues in the past with a bad weld or a poor seal in the exhaust flow that caused the codes at idle or low rpm driving causing the CEL. When my occured it was discovered a crack in the weld at the flange to cats that expanded when it got hot and changed the flow of exhaust gasses, resulting in the code.
you can log o2s see if you messed them: if they dont respond under boost and stay at lambda 1 or so then you know its the o2s.. but in most cases both do not go bad at the same time...
check for exhaust leaks...
if this is a new exhaust talk to John, Im sure he will make it right..
markski
markski
2001 996TT 3.6L and stock ECU
I really am curious to see what the OP's issue turns out to be though.
Does the rear O2 sensor provide any input for the tune, or is it only emissions stuff?
I just threw on some of the spacer/mini-cat things to stop my CEL from coming on (catless exhaust). Car has a tune though I don't know what.
thanks
thanks
Again...these codes are for the pre cat sensors, not the post cat sensors and have nothing to do with cat efficiency.
good luck op
Regarding the extenders, I use them as well and so do many people with cat's removed. They seem to provide just the right amount of exhaust flow to the sensors to keep the mixture just right while preventing CELs so you should have no problem with them.
