Installed o2 bung, still check engine light
I bought 90 degree o2 bungs from ebay (thinking it may solve the problem) p430 code showed up after installing exhaust do to hollowed out cats.
I ordered another set o2 bungs from maxspeed -which they are made for our cars to solve check engine light problem.
I know our ecu is sensitive on some cars: Have you solve this problem by installing o2 bungs?
i installed bungs as i kept getting codes and could not pass inspection (im running 200 cel cats, still not sure why i couldnt pass), the cel kept coming on for a couple of months after i installed them (not driven very often at all), then it just randomly stopped coming on (my car is tuned) that was 6 months ago, everything has been fine since
i believe you test sensdors funcionality by moving the censors from pre cat to post cat, then if the code is the same its not the sensors its something else, if the code changes from pre-cat to post cat or vice versa then you'll know its the sensor(s)
The rear sensors are something like $60 each.
I installed in rear location, you need 90* or you wont be able to fit them do to clearance.
No Tune, but when i visited Markski he flashed ecu, saying this should solve the problem for cat-less exhaust.
Maybe I mixed the sensors while installing the exhaust? I dont remember if length is the same for rear as for the front.
Is it ok to drive the car with p430 code? or its bad for the engine, and will it throw the car in limp mode?
stop by, Ill get that taken care of...
2001 996TT 3.6L and stock ECU
