noise, how to find where it is from?
thinking about it, i don't know if i did hear it with the car in neutral, i do hear it with the clutch pressed in, just unsure if i did the test in neutral or not.
i am confused, not sure i understand what you are trying to say, you mean that having a front diff or not shouldn't change the sound of the transmission bearing? If so, that would mean noise is not from the transmission?
what i am saying ( or did ) is that you would hear the whine of bad trans bearing whether your front driveshaft were connected or not...
and if you do not hear it in neutral ( and i realize it takes a minute to isolate both the source of the noise as well as the conditions in which it is present..) then i am going back to suspecting it is in fact worn pinion/thrust bearings in the box as the cause of your issue. but again, you shouldn't hear it with clutch engaged or in neutral. only while the trans is under ( any ) load.
when i had this issue, it took me a minute to self diagnose that it was indeed the trans ( and not a wheel bearing ) but it was a gut feeling, and a few drives testing the conditions in which it occurred. it turned out i was right, and the box had to be opened to replace the bearings. but all else was fine.
they are sealed and enough ( serious ) heat cycles simply dry out the grease in which they are encased. it's really that simple. though a pita to deal with.
ok well i certainly do hear it with the clutch engaged, in fact, i think it's even a little louder.
The fact that i don't hear it at all with the driveshaft not connected, does that point more towards the front diff? So much that i tried it two times to take it off and put it back on and i really don't have the noise anymore with the driveshaft unhooked.
while i've never heard of the front diff drying up? it has to be possible.
i changed the diff fluid like 3 years ago so i know there is oil in there.
I'll try to see if i can borrow a front diff and do a quick swap to see if it solves it.
thanks for the help
thanks for the help
it does do it when cruising and also when i roll out with the clutch pressed, actually, this is where i hear it the most.
I also hear it, no matter what gear i am in, even on neutral if i am decelerating.
What about the fact i don't hear it when i don't have a front driveshaft?
i have been carefull in my tire choice, i am using 305-30-19 and 255-35-19 front which is pretty close to the stock ratio and i have been running this setup for like 3-4 years.
I have done a lot of track days which might have been hard on the diff though
My front diff output shaft bearing let go a few years ago. I never disconnected the drive shaft, just let my mechanic diagnose it.
The noise was a high pitched whine that started around 30-40 mph and could sometimes be heard up to 60-70 mph. It was generally constant when decelerating/accelerating/cruising, but would would go away for a brief moment (1-2 seconds maybe) when the drive train was unloaded - like cresting a hill during when you transition between throttle to deceleration.
Not really apples to apples with your symptoms, but maybe a data point for comparison sake.
This isn't the power steering pump reservoir noise, is it?
dude, this is exactly the symptoms that i have and at the same speed also and i also get that 1-2 seconds where i don't hear it until i use the throttle again.
So which bearing was it, those that go to the axles or the one connecting the driveshaft to the transmission?
i think we have a winner.
And there is a very good thread about the front differential and many parts numbers from Adam 699 here: https://www.6speedonline.com/forums/...ferential.html
From what I understand, there is a bearing near the half shaft entry. My mechanic did not think that one was serviceable. I assume the viscous coupling has associated bearings, but they were never mentioned. Perhaps they are built-in with the VC?
I was able to source a front diff from another 6spd member. It was more economical than any other option.
I know there was a DIY on this forum from a few years back that detailed the rebuild really well.
