GSR Porsche Performance Throttle Pedal - 996TT/GT2
The GSR Porsche Performance Throttle Pedal - solves the huge problem of the failure prone throttle pedal on all 986/996's.
Through our years of racing and driving these cars hard, we kept running into the same frustrating and dangerous problem of failing throttle pedals. The stock pedal uses a flimsy plastic hinge and thin plastic ribs, 2 separate failure points that both fatigue and break, each resulting in a car that is unsafe to drive. This problem is accentuated by the rigors of track use and heel/toe shifting but is regularly found on street driven cars as well.
Unsatisfied with continually replacing these pedals with the stock flawed part (which is only sold as the complete pedal box assembly) we engineered and produced the GSR Performance Porsche Race Pedal.
Features:
-Attaches to stock pedal box - Fixes your broken pedal assembly without the need for the expensive and problematic factory Porsche replacement
-Works with any 986 or 996 model: cable, e-gas, and cruise control pedal assemblies
-Steel / aluminum hybrid design - provides serious strength and rigidity while keeping the weight down
-More pedal surface area, extends 10mm toward brake pedal to facilitate easier heel/toe shifting
-Features interchangeable face construction to accept custom pedal designs and shapes
-Beefy tubular style hinge that will not fail
-Attractive aluminum finish
-Manufactured in U.S.A.
Vehicle Applications:
1997-2004 Porsche Boxster (986) - All Models
1999-2004 Porsche 911 (996) - All Models
Features:
joseph_number1
07-19-2018 05:45 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
ECS Tuning - VW
08-20-2015 03:07 PM
