Check your wheel hubs if you track your car boys and girls...
I had a left rear wheel hub snap on me after exiting a right hand 1.4G turn at the track last week. No warning. If you heavily track your car I'd consider these a wear item and proactively replace them at some point... It could have been ugly. When these break it causes about $5K in damage as it wipes out the brake rotors, upright, axle, etc. Not cheap...
[url=https://flic.kr/p/yuMdAv]
[url=https://flic.kr/p/za9GRV]
Not really. Besides the hub, the upright and wheel rotor was scratched from where the hub made contact after breaking. I am replacing everything in the rear on both sides with 997Cup and RSR parts to beef everything up. New uprights, bearings hubs, axles, rotors, thrust arms, LCAs toe arms, etc. Might as well while in there...
wow nasty!
any signs of excessive heat build up from a bearing issue?...think the ~cup car spring rates may be partially to blame
'new' hubs seem to have a different design but no change made to the bearing transition area...(hard area to 'beef-up')..the Cup/RSR/R upgrade is probably a smart move on many fronts...
Glad you did not get hurt and the car is fine! Impossible to check but I wonder if the axle was torqued to proper spec. seems very hard in my mind as the splines of the axle pass through the point of failure so that should act like one solid piece of steel with the axle nut clamping it all together at 325 ft lbs of torque.
wow nasty!
Yikes, I have been considering this for a winter mod. This pretty much settles it. Probably going to get new rear LCA and UCA as well. Have heard of those failing too. The rear suspension on our cars take a beating. Especially with the heavy weight and rear bias.
Are you trying to say you would have caught this before it happened by looking at the part? X-ray vision? The part just snapped..
OP - Glad you / the car are O.K.
Exactly. No way to check the hubs. That's why I'm saying swapping them out proactively and doing the bearings at the same time is a wise choice.. Cheap insurance.
New hubs with new studs. Note how the GT2 heat shields had to be trimmed to clear the RS air duct
997RSR LCA. Note the outer monoball and the RS air duct.
997GT3 thrust arm air guides. Note the belly pan NACA duct exit in the wheel well liner and the 997Cup caliper studs
Rear view of the RS brake ducts and the 997Cup toe arms
Close up of the pinch bolts on the 997Cup toe arm. Note the use of a double jam nut arrangement instead of the stock single nut.
Close up of RSR monoball
