MAF - What is it good for, absolutely nothing
Old 09-03-2014, 12:32 PM
'02996ttx50's Avatar
Originally Posted by wolfhedge
BTW those effing 20 or T25 security torx things are redonkulous, then the clip was jammed as well, took me an hour to pry it free, effing awful design by Porsche
possibly you were unaware that in addition to the 2 t20's you have to squeeze the button(s) on the clip while pulling upward to release it from the housing. so it might not be jammed! it's under the rubber bit ( iirc? ). going in, it just "snaps" into place.
Old 09-03-2014, 12:41 PM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Seeing the MAF sensor seems to be merely a few diodes and seems to short out on any rev limiter situation has anyone just tried grounding the filter unit using some cable wires to the rear chassis ground ?
Old 09-03-2014, 12:42 PM
wolfhedge's Avatar
Yeah I knew about the clip, mine was jammed pretty good
Old 09-03-2014, 12:45 PM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
There is more than just a few diodes.
Old 09-03-2014, 01:00 PM
wolfhedge's Avatar
Literal
Old 09-03-2014, 01:19 PM
holy sh*t lol. i always thought the diode was just the exposed one on on the other side :roll eyes: DOH!
well it goes a long way toward explaining why the car runs so badly when they're fried!
Old 09-03-2014, 01:20 PM
fat911's Avatar
fat911 is a jewel in the roughfat911 is a jewel in the roughfat911 is a jewel in the rough
Do the MAFs in these cars go bad frequently? I got the dreaded PSM/ABS failure lights after driving the car hard. I replaced the MAF with a 'gently used' MAF and still occasionally get those two lights.
Very annoying really considering these cars cost $120K+ when new.
Old 09-03-2014, 01:28 PM
^ i wouldn't say they fail "frequently" at all. but i can confirm that they can go bad if you bounce off the limiter. it has to do with increased voltage spikes and can burn them up fast.
other than that, some folks will never have to mess with them during their ownership. the trouble is they can fail intermittently and the car will have all kinds of symptoms ( abs/psm cels/idle hunting/ stutters etc.. ) which wouldn't ordinarily/necessarily lead one to suspect maf failure as the cause.
the codes though, will usually lead to the maf as the source
Old 09-03-2014, 01:39 PM
fat911's Avatar
Thanks for the input.
My mechanic had been driving the car hard and I'm fairly certain he induced the issue without thinking about it.
I'm probably going to throw a hitachi MAF in there and forget about it.
Old 09-03-2014, 01:47 PM
i briefly considered that too. but that involves modding the ypipe/piping and/or tune? and stuff and i don't want anything visibly different if i can help it.
the only option other than oem i would consider would be the proto mafless tune and any/all that goes with it.
Old 09-03-2014, 02:02 PM
wross996TT's Avatar
I would offer, the community does not really understand why the MAF's fail...there are numerous theories, but essentially what happens is air flowing over the "sensor" side (wire) of the MAF creating a temperature and that temperature is compared with the temperature on the other side (of the MAF) to determine theoretically the air mass....which of course may be a necessary input to the ECU to create the appropriate air/fuel mixture for proper combustion.
Now if the air flow is disrupted, contaminated, perturbed, etc. (for lots of reasons...leaks, dirty filters, strange shaped intakes), there could be spikes in the temperature differential resulting in electrical signal spikes and "fried" MAFs. Once fried they can't be saved.
Old 09-03-2014, 02:10 PM
^ that's for sure.
Old 09-03-2014, 02:14 PM
wolfhedge's Avatar
When the car hits the limiter I am sure there is a power surge as power is cut and the MAF voltage spikes and blows the thing... then again who the eff knows... I will put in my new MAf and drive the car str8 to Tims for a mafless and E85 tune,
then I can stop messing around
Old 09-03-2014, 02:21 PM
that's right.
if you're going mafless moving forward? i'd skip putting the new one in!
Old 09-03-2014, 02:49 PM
wolfhedge's Avatar
I paid $180 for it and I have to drive 60 miles to Tim... either that or tow the thing which in NY will be a lot more... and the car is not going 60 miles any time soon without a MAF and its current tune
shifter_
09-08-2015 12:07 PM
jc05e46m3
09-01-2015 07:17 PM
nick49
08-28-2015 01:40 PM
MDYUKI1016
08-24-2015 04:40 PM
Weebs
08-21-2015 06:35 PM
Quick Reply: MAF - What is it good for, absolutely nothing
