Need advice on alignment issue
Old 10-15-2014 | 02:03 PM
Ducgsxr's Avatar
Ducgsxr is infamous around these parts
Alignment question:
I recently had factory ROW springs installed. Afterward, the car was taken to an alignment shop who got all parameters within spec except front caster. The guy said front caster can't be adjusted on a 996TT. The car pulls to the right, and there must be a solution to this. Advice on how to proceed?
Old 10-15-2014 | 02:24 PM
pwdrhound's Avatar
Originally Posted by Ducgsxr
Alignment question:
Press out the front rubber thrust arm bushings form you LCAs and install Tarett adjustable bushings..
Old 10-15-2014 | 02:53 PM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
It would be helpful is you would post your alignment sheet, but there is no reason your car should pull to the right after an alignment, if nothing else is wrong with the car and the alignment is done correctly.
Even if the tech could not get the caster to spec, is should be the same from left to right, therefore not causing the car to pull.
Later, Steve
Old 10-15-2014 | 04:24 PM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Is that an F4U Corsair in the OP's icon... my absolute favorite plane growing up not named SR71 Blackbird
Old 10-15-2014 | 07:27 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
Alignment question:
sometimes the reason are the tyres not the alignment, if a car pulls to one side
Old 10-15-2014 | 09:21 PM
gadangit's Avatar
gadangit is a name known to allgadangit is a name known to allgadangit is a name known to allgadangit is a name known to allgadangit is a name known to allgadangit is a name known to all
Alignment question:
I am in your neck of the woods. What alignment shop did you use? Recommend them?
Thanks-
Chris
Old 10-16-2014 | 05:43 AM
Ducgsxr's Avatar
Thanks-
Chris
I just moved to Houston. Had the springs and alignment done in FL before the move. Will let you know the resolution
Old 10-16-2014 | 07:58 PM
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
Go to f1 Motorsports on memorial drive near dairy Ashford. Just east of drivers source. They will get you setup.
PV=nRT.
09-09-2022 06:06 PM
Rguy
04-12-2020 11:11 PM
cm09578
09-22-2015 06:07 AM
Zero911
08-24-2015 06:51 PM
Quick Reply: Need advice on alignment issue
