How to Remove the turbocharger drain plug?
Old 11-07-2014 | 12:13 PM
Macster's Avatar
Originally Posted by 02black330ci
Next change I am thinking of swapping out all plugs with qwik or ezoildrain ones.
I would not use those drains.
They protrude down and could get knocked off by road debris and cause a bad oil leak that you would not know about until the low oil level light, the low oil pressure light flashed on the dash.
  #32
Old 11-07-2014 | 12:26 PM
rmc1148's Avatar
Agree with above.
  #33
Old 11-07-2014 | 02:58 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
+2
And..Drilled the head off my stuck one a couple days ago and unthreaded the remains, really nice having both plugs functional, reach under and take an oil sample when you feel like it
  #34
Old 11-07-2014 | 04:08 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
and dont forget to rip your filter apart ladies..... and look for Treasure ( shavings ) -
I'm changing my oil tomorrow and if I cant get them off, I CANT help it. and i wont drill it out, or try to force it with a breaker bar.... until my turbos fail and I need to swap for bigger turbos (good reason)
I could use a little bit of heat...or wd-40 and let it soak ...I may find solution.... ill keep you guys posted!
rzmnco
Cayenne 955/957
08-21-2024 09:57 AM
NIKAS
08-20-2019 07:53 PM
ECS Tuning - VW
08-28-2015 11:10 AM
ECS Tuning - VW
08-27-2015 08:50 AM
ECS Tuning - BMW
08-19-2015 09:29 AM
Quick Reply: How to Remove the turbocharger drain plug?
