DIY aircon question
Old 11-03-2014 | 01:48 AM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
DIY aircon question
Guys,
How difficult is it to swap out the aircon radiator condensers and desicator? After replacing the hardware, I assume I will need a full vacuum of the system and then fresh refrigerant and lubricant?
Picked up one of these kits. http://www.design911.com/Porsche/996...-cmo110-ct351/
Cheers, JE
Old 11-03-2014 | 08:30 AM
Slider's Avatar
It doesn't look too hard if you have the equipment to collect the refrigerant...
Old 11-03-2014 | 10:39 AM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
I recently changed both condensers and dryer, it was an easy job.
Remove front bumper
Discharge ac system (recycling is best but 134 is not harmful to the environment)
Remove condensers
Change o rings and re assemble.
Remove Dryer
Change o-rings and reassemble.
Vacuum the system and let sit 15-30 min. to make sure no leaks
Install 31 oz of 134 along with oil (Google amount of oil needed for each part replaced) I used a 12 oz and 19 oz can just to make sure I didn't over or under charge.
Run car/ac and make sure temp drops to 40's
reinstall bumper
done.
At the time, Pelican had the best prices on the condensers and dryer. Parts were under 400 plus the vacuum pump and gauges at harbour freight for about $150. Total job took about 4 hours +/- and much easier than the coolant flush I did this weekend. Good luck.
This was one of the most satisfying DIY repairs. The knowledge I gained is invaluable as it is the same for every car.
Old 08-28-2015 | 01:24 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Resurrection as I am getting ready to tackle this myself. Can you elaborate on the o-rings? As I understand it, I need 4 for the condensers and 2 for the dryer...? Do you, by chance, have the part numbers for the o-rings?
Remove front bumper
Remove condensers
Remove Dryer
reinstall bumper
done.
Old 08-28-2015 | 07:43 PM
03 996tt's Avatar
I bought a generic kit of metric o-rings (make sure they are green and for air conditioning). Actually, I had to buy 2 kits as the condensers require 4 and the kits only came with 3 of each.
Ive helped friends with this since completing mine, the while I recommend changing the o-rings, my cheap friends reused the old ones and we had no issue with leakage. Remember to use some (a/c) oil so they seat easily and dont damage the o-rings .
Look for a of chart of pressures v. temperatures so you can check the gauges properly. the hotter the ambient temperature, the higher the reading If I can find it, Ill post it for you.
One last thing, I put in a few shots of the leak detection dye so should I have issues in the future, it will be easier to track down.
Old 08-28-2015 | 08:48 PM
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
I'm subscribed to this thread, lots of great info. Thank you 03 996tt!!
Funny that a fellow South Floridian has mastered the art of automotive AC...It is so ridiculously hot and humid down here we wouldn't last 10 minutes without AC. My AC is kicking really frosty cold (knock on wood) but at least I know who's brain to pick if I ever have an issue
Old 08-29-2015 | 12:53 AM
ASLAN's Avatar
Thanks for the input!
Money2536
01-19-2022 08:22 AM
Qu4ttro
Cayenne 958
11
09-04-2015 01:35 PM
MadWhip
09-03-2015 02:04 PM
Lucid Moment
08-20-2015 02:22 PM
Quick Reply: DIY aircon question
