replacing turbo return line
I would say it depends on the pressure within those lines under boost. I wouldn't think it would be much. It could be done by cutting the line and removing the kinked segment. The catch is that you can only splice it back in a straight segment.
They are just vent lines - so no, there is no pressure, but at the same time you do not want them to leak.
My lines were cut and modified for a set of aftermarket turbos. I have an "an" fitting on the oil tank, and a line runs up to the metal line. It just has a hose clamp to hold it on.
You could run the an line all the way to the oil tank. I've seen this done with other turbos that have been relocated.
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
