Build thread because why not
Old 11-27-2014 | 09:57 PM
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
People don't often post this stuff so figured I would liven up the build related threads. Short block coming together. Ill keep adding as I go.
Old 11-27-2014 | 10:59 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
Awesome. What liners and Pistons? Also who did the orings
Old 11-27-2014 | 11:04 PM
itguy's Avatar
CP pistons 10:1 with LA Sleeves - I did the o-rings myself
Old 11-27-2014 | 11:18 PM
LQQK's Avatar
Nice. 3.6 I assume. Why did you bump up the compression?
What rods did you use?
Old 11-27-2014 | 11:23 PM
itguy's Avatar
Carillo rods, and bumped compression because it will be cornfed by 2500cc Moran injectors.
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
Whats the full plan and setup?
Old 11-27-2014 | 11:31 PM
itguy's Avatar
Ya, I should have really posted that
10:1 cp pistons 100mm
Carillo rods
LA Sleeves
Tilton Twin + fw
Proefi 112
Twin EFR turbos
225lb Moran atomizers
Ferrea VT
Wavetrac LSD + some Bill Rader trans stuff
Making Intercoolers myself
Fuel system + rails myself
Probably missed some stuff, but that's the meat and potatoes for now. Here is how the car sat before I started molesting it. Changing wheels too, haven't decided yet to what.
Old 11-27-2014 | 11:42 PM
Heads and intake manifold? (saw the valves)
Old 11-27-2014 | 11:46 PM
itguy's Avatar
Ported stock heads, 997 IM, nothing too crazy
Old 11-27-2014 | 11:52 PM
Nice sounds like a good plan. Look forward to following it.
Pump, race or E85? How much boost?
Old 11-27-2014 | 11:56 PM
itguy's Avatar
2 bar on e85, maybe turn it up a little more if its happy at 2.
Old 11-28-2014 | 12:17 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
I was going to post earlier: most of the time people write about what they are doing and others post 'this thread is worthless w/o pics' - you did the other way around. Good teaser pic and that was it.
Looking fwd to seeing more!
Old 11-28-2014 | 12:46 AM
shleitrieg's Avatar
shleitrieg is infamous around these parts
Old 11-28-2014 | 06:49 AM
32krazy!'s Avatar
have you run these before? i know tim was having a difficult time getting them to idle properly with a motec full standalone system.
can you expand a little on why you chose copper over stainless steel for the o rings? love the whole plan. looks like a well thought out setup. were are you located at? would love someone close to me building a big hp car!
Old 11-28-2014 | 09:51 AM
'02996ttx50's Avatar
finally someone else that sees the wisdom of the wavertrac in a fully built car. much success, sounds like a winner!!
Quick Reply: Build thread because why not
