Filters mounted directly on turbo
Old 01-09-2015 | 09:48 PM
BLKMGK's Avatar
If it's not using a MAP sensor and it's not using a MAF that seems odd. I know a bad O2 can make a huge difference, I've seen that before myself.
Just received the 997 Y-pipe I bought off of eBay, not a bad looking piece although at this point I'm not likely to use it and may flip it. The legs do neck down a little bit for sure!
  #32
Old 01-11-2015 | 08:17 AM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Originally Posted by DSCOFF
That's exactly the reassurance I was looking for. Do you know what filter sock you use?
I will check if I take the wheels off today as I am not 100% certain what filter
  #33
Old 01-11-2015 | 08:23 AM
wolfhedge's Avatar
Originally Posted by dkfx
also, have anyone calculated how much whp /mph / 60-130 time / spool you'd increase by going mafless and ditching all that inlet piping? some people say it's not worth it unless you are running big turbos (big tials). I would assume on a k24/18g setup it would pickup spool and some power...i mean if every inlet manufacturer out there says you'll pickup 40whp and 500rpm of spool on a a set of inlet pipes, i'd imagine you'd make AT LEAST that going mafless without ANY restriction on the intake pipes. Correct?
Just trying to figure out where to go with the car next...and still have the stock block stay together
MAF and E20 car did a best verified 7.219 s 60-130 mph
MAFLESS and E20 it goes under 7.0 s every time and the turbos spool way quicker on my 93 oct tune
The car idles at 1000 for 5 secs then goes to 780-800rpm as pr normal within 30 secs
it drives and operates even in these sub freezing temps really well after a 2 minute warm up.
  #34
Old 01-11-2015 | 09:12 AM
BLKMGK's Avatar
Question
What intercoolers are those? No socks on the filters? Do they not get beaten up by suspension movement?
  #35
Old 01-12-2015 | 04:47 PM
wolfhedge's Avatar
ETS intercoolers and the sock was added later
  #36
Old 01-12-2015 | 05:22 PM
32krazy!'s Avatar
have you looked at the fiters recently to see if any holes have been poked into them from the suspension movement?
  #37
Old 01-12-2015 | 06:56 PM
MAXRPM1's Avatar
MAXRPM1 has a spectacular aura aboutMAXRPM1 has a spectacular aura aboutMAXRPM1 has a spectacular aura about
You could do it this way
  #38
Old 01-12-2015 | 06:57 PM
MAXRPM1's Avatar
Another shot.....
  #39
Old 01-12-2015 | 07:09 PM
LuvPorsche's Avatar
LuvPorsche is infamous around these parts
this looks awesome, more details please
  #40
Old 01-12-2015 | 10:17 PM
Slider's Avatar
Jeez, that's art - I could use a high-def version of that for my background!
  #41
Old 01-12-2015 | 10:59 PM
BLKMGK's Avatar
I'd like that Y-pipe and some more details on it please but I don't think I'd want to run the additional piping to the engine bay unless it can be done in a straight shot and insulated from engine heat. Looks daaaamn good though! Nothing drawing a vac on that AOS? I've got one setup like that on another car and think I want to draw vac to remove fumes.
Wolfhedge I think you've sealed my decision on ETS intercoolers :-)
  #42
Old 01-13-2015 | 05:24 AM
wolfhedge's Avatar
No, I am getting up it later this week when it is a wee smidgen warmer here in the arctic north east
  #43
Old 01-13-2015 | 08:42 AM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
The setup in the yellow car is a 997 Setup - airconditioning lines have been changed to allow 997 AMS intercoolers, ypipe, silicon intake off turbos to fabspeed airfilters.
Looks very nice.
  #44
Old 01-13-2015 | 10:23 AM
MAXRPM1's Avatar
Yep - 997 stuff - the crankcase vent/tank only vents from the filter when idling - the line from the left comes from the oil tank into the catch tank and the line coming from the right side of the tank goes to the exhaust so when the car is running above idle it creates a vacuum so all vapors are burned and evacuated - as far as engine heat being an issue for ingestion it isn't - testing on the dyno showed the when the car is moving air flow from the wing openings (Techart) and the top of the deck lid pressure the air filter area and the motor sucks in ambient air The nice thing is that I can drive the car in the rain and not worry about sucking it in - 3071's with a blow through and other stuff done - 1023hp all wheels - picture of the needed fuel system... LOL
  #45
Old 01-13-2015 | 10:26 AM
MAXRPM1's Avatar
And yes, there is a cover that protects all of that stuff and you still can access all of the junk down below if you need.............
Quick Reply: Filters mounted directly on turbo
