Creaking noise going over bumps and turning steering wheel
Old 02-20-2015, 02:52 PM
'02996ttx50's Avatar
well, something doesn't sound right with "everything get used EXCEPT the two large washers".. i'm not sure that advice was given or followed in the four times i/we tried. hmm..
and since i wasn't doing anything but standing there looking perplexed, now I'm wondering if there might've been contributory negligence on my part. but how would i have known ?! grrr.
i just dont recall anyone ( or during this call that took place with tarret ) anyone mentioning the DISinclusion of ANY parts, and those large washers were highly visible and present. by now this has been rendered moot at least for me by my reversion back to oem top mounts, but i am highly subscribed, and curious. thx for posting the results of your inquiry. it sure might be helpful for others to know this, as i still wish i had been able to use them. frustrating ...
  #32
Old 02-20-2015, 03:03 PM
Slider's Avatar
I left the lower washers there because it looked like it was a better shape to press against the rubber on the shock. I initially thought that was what was making the noise, but I tightened the shock so much, there is no way that's moving.
Edit: Did you get any instructions with yours? In my conversations with them, I suggested that would be a nice idea.
  #33
Old 02-20-2015, 03:09 PM
right!?
nope, two camber plates with one of the top pieces that is inserted? ( name is...? ) loose, while one was pre fixed inside. wrapped in bubble wrap. was told plug and play
worst part is, my bud works on these 7 days a week and he's not stupid AND talked w ira.. crazy. "we", as i said,.. just gave up
  #34
Old 05-05-2015, 06:10 PM
Slider's Avatar
Update...
I had fixed my Tarett camber plates using a rubber pad that I made from 1/8th reinforced rubber...
...But the rubber soon began to loose it's effectiveness and I decided to do it right. Taking the design cues from Porsche I knew that I needed this little bump that stops the bearing from moving. The Tarett part does not have it, so the bearing is free to move:
Here is my solution... The inner hole is actually an ellipse, so I made an alignment notch that fits into a hole on the camber plate:
The other side has the missing notch in the form of a raised section. This part is stainless steel.
Now, with the bearing in place there is no movement whatsoever.
I took a test ride over a nice bumpy area and I am please to report - no clunks or noises at all. I will be passing this fix along to Tarett and, hopefully, they will include a similar part with their future kits.
  #35
Old 05-05-2015, 08:01 PM
lol a little late for me,..but i applaud your ingenuity and patience! 3 attempts was enough for me
  #36
Old 05-06-2015, 07:41 PM
NeunElfDrehzahl's Avatar
NeunElfDrehzahl is a glorious beacon of lightNeunElfDrehzahl is a glorious beacon of lightNeunElfDrehzahl is a glorious beacon of lightNeunElfDrehzahl is a glorious beacon of lightNeunElfDrehzahl is a glorious beacon of lightNeunElfDrehzahl is a glorious beacon of light
Rep added for Slider- that's a great idea- and hopefully this will be addressed so we all can use this- I had heard Tarrett's don't work well with OEM struts/shocks, but will stay tuned.
  #37
Old 05-07-2015, 05:07 AM
ya got that right. and yes, rep to slider and one removed from tarret! i only wish i'd happened upon this fix BEFORE i began and gave up on mine
  #38
Old 05-07-2015, 11:14 AM
Slider's Avatar
All ball joints are fine. The issue has been fixed with the mod I posted. Everything is nice and tight now.
  #39
Old 05-07-2015, 01:28 PM
BLKMGK's Avatar
Honjfg was a spam post, reported...
  #40
Old 05-07-2015, 01:41 PM
rmc1148's Avatar
These bot posts are getting out of hand.
COBB Tuning
01-29-2022 09:42 AM
STAGGERED M3
09-11-2015 12:00 AM
no1joey
09-02-2015 12:32 AM
pwdrhound
08-20-2015 05:54 AM
MAcarbon
08-19-2015 04:52 PM
Quick Reply: Creaking noise going over bumps and turning steering wheel
