Can I get away with 87 octane in a 996TT?
I'm dying to get out of Miami tomorrow, but I don't have enough time or fuel to wait in line for 4 hours to get 93 octane. I have access to a large private tank of crap gas (87 octane, I think) that has no problem powering V8 Jeep Grand Cherokees and the like. Can I get away with mixing 5 or 6 gallons of low octane fuel with the gallon or so of 93 that's already in the tank? Will I be OK if I stay off boost? I am using stock ECU.
I have no idea how sensitive these cars are to bad fuel, if you can't tell.
Thanks!
Thanks!
Originally posted by Ferrarislave
I assume it would be fine once or twice, but not something you want to do frequently.
Re: Can I get away with 87 octane in a 996TT?
Thanks!
Thanks!
Originally posted by ar38070
You can run 87 if you want. Keep it off of redline and do not lug it, basically do not run the engine hard. The knock sensors will watch out for you.
actually the knock sensors used in OE systems are pretty poor. They only react to significant detonation (after it occurs) dial back the timing a little and wait for more to see if they have gone far enough...they suck because 1) they are reactionary and require det to occure before they kick in, 2) they only retard timing within a very limited window which is not always enough to prevent further det and 3) they are very poor at sensing highrpm det...oh and 4) often react to false stimuli from other engine vibrations.
That all said...if you are in a pinch and need to get the hell out of Dodge (or Dade) then 89 should be fine for a few gallons mixed on a short trip. keep it cool and donlt load the motor rapidly. Its not like you will blow your motor or anything, its just leads to massive pressure spikes in the combustion chamber that hammer your bearings and rings. I would do it in the same situation....
-dave w
-dave w
Originally posted by 2thfixr
Sorry missed that.... not a bad idea though if I say so myself.
You can add some Toulene (114 oct) or Xylene... do a search online to find ratio... be careful, and DO NOT get it on your paint.
Octane Booster is complete crap... may raise your octane from 87 to 87.3 or something insig.
If you have to run 87, don't get into much boost, and don't lug. And you get to your destination, run as much of the 87 out as you can, and refill.
