My new 710N's are honking!
Old 04-13-2015, 04:31 PM
Carbon's Avatar
Carbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond repute
When my 710Ns went in I had a honking noise and wasn't getting full boost. Finally threw a code and went back to find out one of the hoses had popped off. Haven't had any issues since then.
Note that these and OEM are diaphragm based while aftermarket DVs are piston based. They won't honk, but there have been cases of them getting stuck open and needing some help.
Old 04-13-2015, 06:38 PM
'02996ttx50's Avatar
iirc the 710A is oem fitment(??) while the sturdier(?)710N is not standard but considered an upgraded dv.
Old 04-13-2015, 09:43 PM
mrmaass's Avatar
mrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond repute
That is correct. Externally the oem looks identical to the 710N.
Old 04-25-2015, 05:50 PM
mrmaass's Avatar
EvoMs. sturdy as they come and no randy geese will follow you
http://www.evoms.com/EVOMS_Porsche_D...dv90degblk.htm
Just put these on last night and got back from a drive. I can't believe how much better it is running now. I really underestimated the role of the DV. Having honking diverter valves that leak is not only annoying but really takes away the smooth driving and acceleration that the car is capable of.
I thought the boost of my A28's just came on abruptly and because of my injectors there was no way I could have a modded car that would run as smoothly as a stock one but I had let myself get used to failing diverter valves.
If your's are on the edge and making bad noises do yourself a favor and replace them!
Old 04-26-2015, 01:49 PM
the EvoMs dv's are indestructible far as i can tell! i'm glad ya got them, you won't be thinking about those for awhile, if ever again
Old 04-26-2015, 06:01 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
am thinking that the honk comes when u shift , is this correct , if so they are letting the excess air out thus blow offs
Old 04-27-2015, 05:35 AM
point is.. EvoMs dv's won't ever "honk". a superior upgrade over 710's a OR n's.
Old 04-27-2015, 07:01 AM
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
Mine honked when I would slowly accelerate. They would honk(or more like a hum) at about 3K RPM. They only did it for the 1st month or twoand dont do it anymore.
Old 04-27-2015, 10:23 AM
mrmaass's Avatar
Yes, that is what mine were doing. Under light-moderate load they would make an extended honking sound. Sometimes even steady state cruising would cause them to make this sound and it was not only annoying, but now that I've replaced them with EVOMs DVs I know they were robbing performance and drivability too.
The nice thing about the EVOMs product is that they fit perfectly where the old ones were because they are only slightly larger.
Old 04-27-2015, 01:54 PM
cburke996's Avatar
cburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of light
The new 710N's are no longer made by Bosch - a company called Kayser makes them now. I had Bosch ones for about 2 years with no issues. Eventually one failed and I replaced it with a new 710N. That thing honked like crazy right out of the box. I returned it for another one, which also honked. I've concluded the new ones are junk. I pulled them out and replaced them with Forge DV's, which have been trouble free for about a year now.
Old 04-27-2015, 02:29 PM
mrmaass's Avatar
You're right - the ones I just pulled were made by Kayser,not Bosch. My new DVs have made such a difference I'm still in disbelief (I just got out of the car so it's fresh in my mind again).
Racer911S
01-13-2010 09:48 AM
Zippy
09-07-2008 09:23 AM
cephas
06-02-2008 04:24 PM
calh4289
12-01-2006 10:30 AM
Quick Reply: My new 710N's are honking!
