996TT Engine pulling experience
#106
will try a site previously suggested
#108
Wow, I think I'd be putting some additional support on that table and perhaps cross ties on the legs! Didn't use the Harbor Freight hydraulic table? Looks so easy to work on now!
#109
Don't have Harbour Freight up here so had to make use of what was available. This is a case of lifting the car off of the engine...table is a little flimsy but seems to be holding up....
#115
Engine installed last March, drove the car until mid September. Getting ready to install suspension goodies and a different exhaust system. Unfortunately, lost the use of the shop I was working out of so this year I will be ground level.
#118
Fixin' to drop
I will be droping my 996tt engine and transmission in the morning. Its an 03 and just broke the 30k mile marker. This is the best write-up so far. I don't see the need to search anywhere else as this thread seems to cover it all. Have the car lift, HF table, and lots of tools. I/we shall see .... Pinning, hoses, plastics, slave reservoir, coils, plugs, pressure wash, etc.
#119
badd ***
that has to be the coolest diy i have ever seen.
I'm doing it next month!!! to pin my coolant lines!!!
and replace clutch!! you close to seattle??? hopefully i don't have to fly you in)))
#120
Help Recocgnizing
Trans Shifter cable ends
Retaining clip
Hi folks ! I wonder if anyone can recognize the shifter cable ends on my 996TT. These are not original, but I believe these are common. My problem is that I can't get them off of the shifter levers at the transmission even after removing the retaining clips. Pics are attached for review. Please advise what is the trick! Thanks to everybody !!!
