ERP triple clutch
Old 05-21-2015 | 09:39 AM
Originally Posted by johnny.dangerous
seems a little grabby as it engages.
because that is an older version. new ones engage dead smooth, you can take off without using the gas pedal
#TeamAIM
Old 05-21-2015 | 10:22 AM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
When did the newer one come out because the guy it came from said its the newer version, well newer than the one Elite is selling in the for sale forum, at the moment its a bit switch like, not really smooth at a;ll but it feels like you can throw anything at it and it will take it !!!
Old 05-21-2015 | 04:53 PM
32krazy!'s Avatar
layinback had the newest version back in 5/2014. i have his car now and the erp has very little chatter and engages smooth and releases easily.
Old 05-21-2015 | 10:03 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Prior to even considering my upgrade, My 3X steel ERP had no chatter with sport mode on. I was impressed by it. It will also hold a lot of torque.
This is a great clutch and I truly feel that the recent update is another step up for them as their "Fixes" weren't current problems for me.
My updated clutch is for sale at 3K, I am thinking about keeping it and reinstalling it if I cant get 3 for it.
This setup worked for me before and, after running my new setup, I can say that some of my clutch issues, were not the clutch at all.
Old 05-22-2015 | 03:06 AM
Dude do you have any contact details for ERP ? Where did you get yours updated? Mine does not chatter and the pedal pressure is lovely but the engagement range is around 1/2 inch, i can drive it fine but anyone else gets a shock until they get used to it. You can feel it holds the torque easily.
Old 05-22-2015 | 07:43 AM
there is nothing that can be done for "engagement range" to the actual clutch. they tried and that is where some of the side effects arose with the middle revisions that people had trouble with. the only way to change the "range" is to get a different slave or master cylinder. also using an RSS clutch pedal stop helps too. i am going to mess with that on my car when i switch it over to the ERP this winter.
#TeamAIM
Old 05-22-2015 | 08:00 AM
Im glad its not just meAny ideas on what slave we could use? Also it may be easier to control if it grabs lower down so that going to be a shorter pushrod I presume? How does the pedal stop work and where is the best place to get one? sorry for all the questions but Id love to get this driving a little more 'factory'
Old 05-22-2015 | 08:08 AM
lol drive factory with a LWFW and a triple disc made to hold 1300hp - gotta have realistic expectations here.
pedal stop takes away empty travel at the bottom of the pedal so it basically does what you said, makes it feel like it grabs lower and its easier to modulate. length of the rod will not do the trick its a hydraulic system so the volume of the slave and master cyls is what needs to change.
#TeamAIM
Old 05-22-2015 | 08:16 AM
Ok so increase or decrease the bore size? Either way are there any clues as to what part might be useable? Im up for experimenting and publishing results but need to know where to start, what bore is a GT2 slave? I have a normal 996/Boxster master I think.
Old 05-22-2015 | 08:23 AM
... that depends on whether you are going to change out the slave or the master
#TeamAIM
Old 05-22-2015 | 08:27 AM
I think slave is easier
Old 05-22-2015 | 04:14 PM
BLKMGK's Avatar
Larger bore slave or smaller bore master I think. Push less per stroke from the master or use more fluid to move the piston on the slave. IMO the master would be easiest to work with, my understanding is that the GT2 part is the same as the Boxster. Anyone?
Old 05-23-2015 | 02:42 AM
The reason I say slave is that the Master looks a little 'unique' whereas the slave is well slave shaped!!! Anyone got an idea of slave cylinder bore for a GT Slave??
Old 05-25-2015 | 03:19 AM
Guys, anyone know the difference in size between a boxster and turbo master cylinder?
Edit Carrera and Boxster share a 19.05mm bore master cylinder, just need to find Turbo bore size now.
Old 05-25-2015 | 11:24 PM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Interesting topic of conversation. I have been holding off on this clutch as my ~700ft/lbs of torque at the wheels has been held by a Sachs clutch so far. Glad you guys are working this out though, I wish the guys in the 997 forum paid attention to these kinds of details...
Quick Reply: ERP triple clutch
