Cross Reference for 996 TT Flex Disc aka Guibo?
thanks!
I removed mine, it turns out I have the right one and I think the cardan is sticking on the splines as it should pull up all the way (so the guibo is correct, but the cardan is stuck and I tried a rubber mallet)! So Im about to try and remove it, regrease it and refit, hopefully it will go on correctly after that. thanks again.
911mike
08-05-2009 02:58 PM
