Crazy issues....
Old 06-20-2015 | 07:22 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Crazy issues....
So, car has never skipped a beat. Removed the cardan shaft only to go dyno. Drove fine for 30min. Then every light possible came on. First was battery discharge light, then brake distribution, then all the abs, psm. Car went in limp mode. Brought it home and read the codes. Was just o2 sensors and cats. Erased everything. Went to start the car again and it won't start, just cranks and smells very strong of gas. Just tried to read codes again, none found. What happen?!?!
Old 06-20-2015 | 08:50 AM
VGLNTE1's Avatar
Hooked the shaft back up. Car started and idled fine. Drove it 30 feet and brake distribution came back on. Voltage metered pegged. Battery seems hot to the touch. Soon as I slow down all the lights go back off. Car won't make any boost.
Lost......
Old 06-20-2015 | 09:21 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Weird....All the battery connections tight?
Funny how weird crap goes on when doing something that should be unrelated. DERP.
Old 06-20-2015 | 09:22 AM
rmc1148's Avatar
Sounds like over charging/regulator but other issues make that not seem 100% I doubt it would help but try disconnecting battery for about 30min. Check ground in rear engine area and as noted battery connections.
Old 06-20-2015 | 09:29 AM
VGLNTE1's Avatar
Battery is tight and did disconnect it for a while. Car now starts, but same issue. I will add I washed the car a day before this happen. But I never even spray water in the trunk area.
Old 06-20-2015 | 09:51 AM
rmc1148's Avatar
Have you checked output of alternator?
Old 06-20-2015 | 09:54 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
I agree with the other guys. I'd be looking at the battery and alternator.
Old 06-20-2015 | 09:59 AM
VGLNTE1's Avatar
Nothing yet. To check the output should I pull it and have it tested at auto zone?
Battery is new and voltage has been fine. I noticed with the gauge pegged the battery was hot and the vent hose to it was unloading alot of fluid..
Could this be the voltage regulator ?
Old 06-20-2015 | 10:12 AM
Macster's Avatar
Yes.
Old 06-20-2015 | 10:32 AM
rmc1148's Avatar
^ Agree
Old 06-20-2015 | 10:54 AM
VGLNTE1's Avatar
Pelican parts best place?
Old 06-20-2015 | 11:05 AM
rmc1148's Avatar
You can buy new or rebuilt and also just replace regulator, may find one local if in a hurry. If the car has lower miles I would replace regulator if not rebuilt alternator= pelican does have one for around 420.
Old 06-20-2015 | 11:43 AM
VGLNTE1's Avatar
Car has 105k. I bought the regulator. See if that works
Old 06-20-2015 | 01:42 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
bro sounds almost like what just happened to me turned out to be a blown MAF which was also what i checked last.
No codes present on my durametric.
Disconnect the MAF if it runs its ur MAF.
Cheers
Old 06-20-2015 | 02:06 PM
VGLNTE1's Avatar
Cheers
You had voltage pegged on the gauge? The car idles and drives perfect....besides zero boost and flashing cels
Quick Reply: Crazy issues....
