F430 vs stage 1 996TT?
Old 11-13-2005 | 08:51 PM
scott's Avatar
scott is infamous around these parts
Heated discussion at dinner tonight. Bro in law says the 430 will smoke a stage 1 TT. I say no way... Anyone done the comparison?
Old 11-13-2005 | 09:04 PM
AMG ETR's Avatar
Won't smoke a stock turbo.... Had fun with a 430 with my stage 2 and boy was he pissed
Evan
Old 11-13-2005 | 09:14 PM
Ferrarislave's Avatar
Ferrarislave is infamous around these parts
Take it to the track and find out, the F430 won't smoke a Turbo, but it won't be behind.
Old 11-14-2005 | 12:37 AM
iLLM3's Avatar
Exactly!
Old 11-14-2005 | 02:00 AM
Ruiner's Avatar
I would think that it would be pretty close. The turbo would have a torque advantage, but the F430 Coupe would have the weight advantage. Power would be rather close between the two given the increase of ~6psi on the turbo. I am not sure what the final drive gear ratio is for the F430, though (I've seen 4.30, 3.55, etc). We know the 911 turbo 6sp sits at 3.44.
Old 11-14-2005 | 02:04 AM
Life Dies's Avatar
Life Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud of
You can't compare the diff ratios on two different vehicles unless the overdrive (6th gear) ratio is identical.
Old 11-14-2005 | 11:15 AM
Ruiner's Avatar
What does overdrive have to do with it? If you never make it into 6th, it becomes a moot point. 6th gear won't matter if your race runs from 3rd to 5th gear. The final drive coupled with the gear ratios give you a final drive ratio for each set of gears. The stock rear-end will give you a hint as to acceleration if the gear ratios for both cars are on par with each other. The final drive gear ratio (rear end x the current gear that you are in) is what will help provide more insight.
Old 11-14-2005 | 12:54 PM
Johnfromjersey's Avatar
Johnfromjersey is infamous around these parts
i dont care which one is faster. clearly the TT is, but id so much rather have the 430..beating other cars doesnt give me my enjoyment. the fun factor involves me and an open road. no need for the street racing
Old 11-14-2005 | 01:10 PM
Ruiner's Avatar
Stock for stock, the F430 would run away from the 996TT in almost all instances I do believe. Then again, we are comparing a "new" Ferrari to a 5 yr old Porsche. The 997TT might even the score, but who knows. Weight will play a huge roll...
Old 11-14-2005 | 01:49 PM
i think his comparison is of a modded TT to a stock F430? . my understanding of Stage I is ecu, diverter valves, air filter/intake. good for 490 hp/ 500 tq. 430 is rated at 490 hp/ 343 tq. Quite a difference in tq should give the TT the clear advantage IMO. Regardless, the 430 is the winner in overall car experience
Old 11-14-2005 | 02:14 PM
Ruiner's Avatar
It would be close. Added torque, but also added weight of the AWD system. I'm a Porsche lover and have never been a big fan of Ferraris. To each their own...
Old 11-14-2005 | 02:44 PM
20C4S's Avatar
Fadi
08-17-2018 05:16 PM
Zmydust
09-07-2015 01:43 PM
petron5000
09-06-2015 11:20 AM
Quick Reply: F430 vs stage 1 996TT?
