Stephen/Imagine Builds a Great Engine
Old 11-14-2005 | 10:52 AM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Prior to having Stephen/Imagine rebuild my engine, I had been losing a certain amount of oil ever since I acquired the car. I kept my garage stocked with oil and periodically dumped in a quart or more.
I have put a few thousand miles on my car since the engine rebuild, and I have not lost a drop of oil. I checked it last night and I am full. Stephen/Imagine builds a tighter engine than the factory.
Thanks Stephen!
Craig
Ps: Anyone want to buy my extra supply of oil. It doesn’t look like I will need it anytime soon.
Old 11-14-2005 | 11:06 AM
cjv's Avatar
cjv
Moderator
Re: Stephen/Imagine Builds a Great Engine
Thanks Stephen!
Craig
Craig,
I'm sure Stephen builds a great motor.
One hugh factor determining oil consumption is how the motor is initially broken in.
Old 11-14-2005 | 11:07 AM
JP-S-St.Louis's Avatar
Just a boxster?
JP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond repute
Great car man! Congrats, 800hp has to be a blast.
Is your car still up to day to day use?
Old 11-14-2005 | 11:13 AM
Craig's Avatar
Re: Re: Stephen/Imagine Builds a Great Engine
Originally posted by cjv
Craig,
I broke the motor in for longer when I first acquired it, as opposed to following the rebuild. On the other hand, I did not follow a particular break-in protocol the first time around, whereas I did the second time.
Craig
Old 11-14-2005 | 11:14 AM
Craig's Avatar
Absolutely!!!
Craig
Old 11-14-2005 | 11:17 AM
cjv's Avatar
cjv
Moderator
Craig,
I know this doesn't apply now ................ but it makes for some interesting thought.
www.mototuneusa.com/break_in_secrets.htm
Old 11-14-2005 | 11:25 AM
trekkyy's Avatar
Member
trekkyy is infamous around these parts
cjv,
A little off topic, but thats exactly how we break in new piston engines (internal combustion engine) in aviation. RUN IT HARD
Old 11-14-2005 | 12:06 PM
Orli930's Avatar
Orli930 is infamous around these parts
I would have to say that Steve is the best
Old 11-14-2005 | 12:57 PM
Johnfromjersey's Avatar
Johnfromjersey is infamous around these parts
good to hear Craig...dont sell the oil...oil changes are still needed
Old 11-14-2005 | 01:28 PM
sticky's Avatar
sticky is infamous around these parts
Craig, what ever happened with your custom exhaust being replicated for others to buy? Is that still on or is fabspeed still the best way to go for performance?
Old 11-14-2005 | 02:51 PM
95RogueM3's Avatar
95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of
Is that the method you recommend/employ yourself with new motors? (Its just totally flying in the face of all info that typically surrounds engine break-in..)
Old 11-14-2005 | 02:55 PM
cjv's Avatar
cjv
Moderator
I broke in my first 996tt motor on the dyno. The current motor build will be broken in on the dyno just like they describe on the above website.
Old 11-14-2005 | 07:43 PM
PorschePhd's Avatar
Criag,
Thanks for the kind words. I am glad it is all good. I try not to ever let anything out of my hands that ins't just the way I like it. I am pleased with the outcome and even more pleased you are happy.
Old 11-17-2005 | 01:09 PM
jayster's Avatar
jayster is infamous around these parts
Interesting link, should be very thought provoking...
In grass roots racing (no budget) the only way to break in your engines was to run it hard, right off the trailer. If you didnt your qualifying times sucked, then you start from the back. Then you will break it in trying to catch up...Anyways, during assembly , I used barely enough oil on my rings (conventional, not synth.) to aid in assembly AND quick run in, to seal the rings.
Old 11-17-2005 | 02:02 PM
StephenTi's Avatar
StephenTi is infamous around these parts
I wanted to give you my left-over Mobil 1... guess your Turbo has use for it anymore, lol...
Quick Reply: Stephen/Imagine Builds a Great Engine
