I think I found my misfire
Every plane of this coil (#4) had cracks in it!
On a positive note, the plugs looked great! I still installed new replacements, but the condition of these makes me confident the old lump will be back to her best with the new coils.
Crappy iphone pic. Came out very dark. I agree if they really looked that colour that would indicate a mildly rich condition.
The colour is actually much lighter than in the pic.
Durametric indicated excessive misfires on cylinder 4. Spot on diagnosis IMHO based on the state of that coil.
All the other coils looked just fine.
I always tell clients to change plugs and coils especially on tuned cars...
2001 996TT 3.6L and stock ECU
It wont be the plugs in your case, however, your symptoms lead to electrical... In your case, battery or charging system and/or cracked ignition coils. My prediction here, if im correct, is that you probably didnt change out the coils when you changed out those plugs? Best way to check, pull off the 4 T-30 chrome bolts to remove the coil covers on the drivers side.. then remove the first two coils and carefully examine for cracks in the boot... It might even look like a line that is from oem, so check carefully. And for battery, check the date.... If its anything close to or around the 5 year mark(give or take a year), then high chances it is the battery. And hence, the crc intake valve cleaning helps here too... less load on the engine.
Just to close this off, I replaced all 6 coils with with the latest Porsche parts and plugs with OEM equivalents. No misfires since then.
Of course, now I'll have gone and jinxed myself....
vogz
09-19-2015 01:02 PM
boxercupdave
09-15-2015 05:00 PM
