Proefi Can Display
Proefi Can Display
Can anybody running the Proefi can display comment on what adjustments are able to be made when plugged into the stock EC you and not running a Proefi ECM?
How do you like it?
How do you like it?
i like the logger its easy just plug a flash drive in and it logs automatically. having about 15 different gauges to monitor while driving is nice as well. same with the hp/ft/lbs screen is kool
That's what I'm wondering, so it cannot be wired into the stock computer, as in like plugging into the OBD port?
QUOTE=32krazy!;4404721]I'm not sure what your asking. the can display is wired directly into the proefi computer and has nothing to do with the factory dme. the display is a logger and display and no adjustments can be made thru it. theres another cable that is purchased and plugged into the proefi computer to allow a laptop with the proper software to interface with the computer.
i like the logger its easy just plug a flash drive in and it logs automatically. having about 15 different gauges to monitor while driving is nice as well. same with the hp/ft/lbs screen is kool[/QUOTE]
pwdrhound
11
11-25-2015 01:18 AM
