Rear viper scratching C-pillar
Old 09-28-2015 | 06:48 AM
rmc1148's Avatar
Be careful when lifting/washing car etc. This has been a problem with front wipers forever as far as damaging hood if left in up position and then opening hood when drying car.
Old 09-28-2015 | 06:49 AM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
I got those marks as well!
But thats another discussion
Old 09-28-2015 | 10:05 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
I like rear wipers, and i use it in rain or snow ^o^
Old 09-28-2015 | 10:26 AM
Zuhl's Avatar
Zuhl is infamous around these parts
I cut a piece of 1" foam pipe insulation (less than $3.00 for an eight foot length) the length of the wiper blade of slide it over the wiper blade and arm any time I raise the blade. If the arm is bumped and falls over foam hits the car not the metal part of the wiper blade. Problem solved.
Old 09-28-2015 | 12:32 PM
khiroshima's Avatar
khiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond repute
http://rennlist.com/forums/996-turbo...ighlight=wiper Post 16 mentions using zip tie to secure wiper, also could just remove as talked about.
Yeah, I read about this over there too, I did the zip tie thing and haven't looked back-- Easy and hardly noticible, KH
Old 09-28-2015 | 01:46 PM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
take it off......you dont need it
Old 09-29-2015 | 10:57 AM
sanyata's Avatar
sanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud of
There are mini zip ties that are maybe 1/16" wide that you can barely see when used. Like you said, quick, easy and hardly noticeable.
Old 09-30-2015 | 06:38 AM
cburke996's Avatar
cburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of light
Happened to me also. Pisssed!!
Old 10-01-2015 | 10:40 AM
Highlander's Avatar
Highlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond repute
I like this idea. Nice and simple.
Mackchacha
07-09-2019 11:03 AM
JayJayJohn
09-17-2015 05:09 PM
Mar48
08-24-2015 01:13 PM
Glasig
08-23-2015 03:35 PM
Quick Reply: Rear viper scratching C-pillar
