getting car aligned - tomorrow
Car goes for an alignment tomorrow, no track days. Been using same alignment shop for years, they do amazing job. Car sits on h&r lowering springs, should i go with stock spec? oem wheels and tires
after putting good amount of miles, so the springs settle down a bit (looks like front tires inside show no wear but rear ones (inside) do get some tire wear.
Now, car sits on winter tires, front ones are 245/40/18 and rear ones are more skinnier 275/35/18
no. x73 and/or the computers gt2 specs. adjust to your liking. probably less toe in. to adjust for hard accel "squat", coupled with lowering spring sag. should also be using ( or give serious thought to ) adjustable toe links.
i've managed up to .25 "toe in" each side ( rear ) up to .027. and it helps to lessen/eliminate that inner premature inner cord tread wear. i couldn't have accomplished that, absent aftermarket toe links. max prior was *maybe* .023 ( IIRC??! ). whatever it was? wasn't enough - toe in. now perfect.
I always ask how someone wants their car to drive...alignments make massive changes to how a car responds and gives 'outputs'...
Main desires/concerns? Willing to have tramlining? Aggressive throttle/brake/cornering, or more normal cruising?
Cheers,
Cheers,
I've got the SAME issue and have t been able to find replacement tires - kuhmo? Will be having toe links installed when it goes in for alignment and would like to get better wear from the replacements when I find them
![Frown](https://www.6speedonline.com/forums/images/smilies/frown.gif)
but now the car rarely sees the city at all, so my alignment setting has been optimized and reflects the majority of hard uphill turning ( well, i go back down the hill too lol )
but good points as always ...
Car aligned, it drives and handles even better!, alignment was super off. I dont think the previous owner even did alignment since the car was new.
now I need to find good rear tires for summer but that can wait, right now the car sits on winter package
with blizak's mounted. And i fully agree about PS2's.
Attachment 1
![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
Attachment 1
Jrox
09-25-2015 07:12 PM
terpsred
09-21-2015 06:52 AM
