I have been offered GT3 brakes, should I run with them?
Old 11-18-2015 | 11:31 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Jim, if they fit, run them.
Please report back on your results.
Pwdrhound knows more about this then I do but, My opinion, a 1mm offset in regards to caliper clearance shouldn't be an issue. Just from memory, I think I have around 5mm on both side with the stock setup. 1mm to one side should be okay from an operation stance.
Caliper not being centered would offset itself by brake channel pressure.
Just remember, this wouldn't be OEM by any extent. If it works, I think we all may be interested in the results.
You may find that the inner or outer brake pad may possibly wear faster.
  #32
Old 11-19-2015 | 12:03 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Originally Posted by JimTT
i can ask him to look out for another set if you wish.Yep, will do. GT3 996.2
Sounds good Jimbo mail me if he does
  #33
Old 11-19-2015 | 12:14 AM
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
This is exactly what my indie said but Powdrhound changed my mind. I trust powdrhounds endless experience.
  #34
Old 11-19-2015 | 12:15 AM
timccloud's Avatar
More reps for you Jimbo great overall post
  #35
Old 11-19-2015 | 12:27 AM
elite1's Avatar
Well, im not here to challenge Pwdrhound's 996 or 997 knowledge but, if, you decided to move forward with your decision, what would one expect?
I believe that everything would be fine by the numbers presented.
BTW, Pwdrhound is a very good friend of mine. Just like to challenge the "impossible" at times.
  #36
Old 11-19-2015 | 01:17 AM
JimTT's Avatar
Thanks Tim, I'll keep you posted.
Yeah I almost accepted it, the fit looked really good, I drove it for a short distance and felt fantastic but 3 strikes and its out, well... 3 very experienced members anyway, Pwdrhound, Rob and Kevin (UMW) changed my mind for me.
  #37
Old 11-19-2015 | 01:33 AM
pwdrhound's Avatar
IMHO, brakes are too important to not set up right. The problem with even a 1.5mm difference in offset does not come into play with full thickness pads but could be an issue of you were to run the pad down to the backing plate or if you had a brake pad fail as I have had happen to me. The brake pad friction material detached from the backing plate and completely slid out of the caliper. The pistons than have to extend out to basically their maximum to compress the thin backing plate against the rotor. If the rotor is offset an extra 1.5mm away from that side of the caliper, you may actually have the pistons come out completely out of the caliper body. That will result is a total brake failure as your pedal will completely go to the floor. This is not what you want. I'd sell the GT3 rotors and get OEM TT rotors which are dirt cheap anyway. Do it right or don't do it at all. That's my moto... I've learned the hard way before..
Hey Elite, how's the smoke system working on your car? I gotta check it out...
  #38
Old 11-19-2015 | 01:40 AM
JimTT's Avatar
Thanks for explaining John and I totally get it.
So the rear GT3 996.2 rotors are fine but the fronts need to be 997TT with GT3 rotors, spacers not required.
  #39
Old 11-19-2015 | 01:49 AM
pwdrhound's Avatar
The rear 350 rotors are all the same on the 6/7TT, 6/7GT2, 6/7GT3 and 6Cup
Front rotors must be 350 TT versions.
  #40
Old 11-19-2015 | 01:58 AM
JimTT's Avatar
Oops meant fronts need to be 997TT rotors with GT3 calipers.
  #41
Old 11-19-2015 | 04:28 AM
timccloud's Avatar
Thanks Jimbo and Hound thats what I thought.
  #42
Old 11-19-2015 | 07:40 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
Glad you are not accepting it with GT discs and are going TT versions, only way I'd accept it
+1, exactly what I was talking about over on RL. I might measure piston heights over the winter and see if there is a safety margin here....is there anyone with experience running the mismatch brakes down to the backers?
Can also use Panamera rear discs
Cheers,
Rob
  #43
Old 11-19-2015 | 02:23 PM
JimTT's Avatar
He's asked for an extra $300AUD = $216USD for the 2 front 997T rotors, he said they cost him double that but is prepared to split the cost. Is it OK to use lightly used old pads with new rotors? I will also ask if he cut the pins on the pads, if he did then no go like Rob said.
So all up incl install $2800AUD = $2014USD
  #44
Old 11-19-2015 | 03:08 PM
JimTT's Avatar
He said he didn't cut pad pins but knocked them back a little, does this sound ok?
EDIT; He's pressed the pins down a fraction, I'm assuming this is OK?
  #45
Old 11-19-2015 | 03:29 PM
timccloud's Avatar
$300 aud for two 997T discs is ok Jimbo the four I bought from Pelican few months back cost me around $750 shipped no idea about the pins though
Quick Reply: I have been offered GT3 brakes, should I run with them?
