I have been offered GT3 brakes, should I run with them?
Old 11-13-2015 | 02:15 AM
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
I have been offered a complete set of near new GT3 brake calipers, discs, pads and brake lines for a really hot price. My brakes as they are seem fine for my use BUT I'm very tempted.
I could put my brakes up for sale and reap some of the cost. Is this a good idea?
Old 11-13-2015 | 02:18 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Jimbo if u dont want them let me know as then I can put my 996T brakes on the Boxster
Old 11-13-2015 | 02:23 AM
JimTT's Avatar
Ok, ok, I'll let you know. I told him yes on the spot but then I said I might do a bit of research first.
$2500 fitted with yellow pagid pads and race fluid.
Old 11-13-2015 | 02:34 AM
timccloud's Avatar
$2500 with pads and no shipping from the states absolutely mad if u dont buddy
Old 11-13-2015 | 02:38 AM
JimTT's Avatar
Kevin from UMW said I will need 997TT front rotors as the GT3 ones will not fit . I'll get more info.
Old 11-13-2015 | 03:01 AM
timccloud's Avatar
Yes 350mm same as what I just fitted with spacers so i can run the standard 996T calipers.
I dont think you need the spacers with GT3 calipers though not really sure.
Pelican has a range of 350mm disc options in the 997T brake section.
Hound or krazy or anyone else who knows much about this than I hopefully will chime in and point you in the right direction.
Put them in the cupboard and fit once your current rotors have worn out.
Old 11-13-2015 | 03:27 AM
32krazy!'s Avatar
from what i understand the gt3 front rotors won't fit a turbo unless the front spindles are changed. the rotor hat offset is to narrow for the angled spindles of a turbo. check and confirm before buying
btw you can get turbo calipers and rotors that fit without modification for not much more than the 2500$. 997 turbo is an upgrade and direct fit
Old 11-13-2015 | 05:08 AM
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
Originally Posted by 32krazy!
from what i understand the gt3 front rotors won't fit a turbo unless the front spindles are changed. the rotor hat offset is to narrow for the angled spindles of a turbo. check and confirm before buying btw you can get turbo calipers and rotors that fit without modification for not much more than the 2500$. 997 turbo is an upgrade and direct fit
hey Steve , 997turbo breaks fit 996 turbo without modification ?
Old 11-13-2015 | 06:29 AM
32krazy!'s Avatar
Yes I have them on my turbo
Old 11-13-2015 | 01:08 PM
JimTT's Avatar
Ok, thanks. Its at a Porsche indie shop, 'll ask a few more questions.
Old 11-13-2015 | 01:09 PM
pwdrhound's Avatar
There is a set of mint condition 996Cup brake calipers on sale in the Cup car forum on Rennlist. They are asking $1600 for the fronts and $1000 for the rears. That's a great deal..
Old 11-13-2015 | 02:43 PM
JimTT's Avatar
Are cup ones that much better than GT3?
Local GT3 ones incl pads, fitting & race fluid 2500AUD = 1782USD
Old 11-13-2015 | 04:39 PM
32krazy!'s Avatar
you can reuse the rear turbo calipers and add a 10mm spacer and longer mount bolts. i think john may even have a set. then 350mm rotors front and rear from pelican for cheap or giro disc for about 2200$ 6 piston fronts,pads and your golden. all the brakes a street car will ever need.
Old 11-13-2015 | 04:57 PM
JimTT's Avatar
Very good info, thanks Steve.
Old 11-13-2015 | 05:17 PM
32krazy!'s Avatar
of course I'm sure you know that for a street car or just about any car that isn't driven at pwdrhounds level the factory 4 pot f/r is more than enough brakes for the car at most any power level with the right rotors and pads. of course the 6/4 has more bling (and mine were free so i jumped on them) but i would be hard pressed to pay for a caliper upgrade unless its a serious track rat.
Quick Reply: I have been offered GT3 brakes, should I run with them?
