Head Gasket sealing area - sleeves
Old 12-19-2015 | 05:39 PM
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
Originally Posted by Macster
Well, thinking out loud if the rust/corrosion can be dealt with to then ensure the proper sealing of the liner perhaps a shim can be placed at the bottom of where the liner fits -- if this is already machined -- or if the block not yet machined to take the liners the depth of the liner bore machined just a bit shallower and the top of the liner then re-machined -- just enough to remove the damage -- and bring the height of the liner to match that of the block deck and thus these liners used?
Good idea but it will be harder to find precision ground shims the exact same shape as the liner resting ledge. Its hard enough to fine precision ground shims for installing transmission parts.
Old 12-20-2015 | 04:40 PM
turbodanny's Avatar
turbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond repute
How could a company get away with selling a less then perfect product? Is there a fix, maybe but should you have to? NO! If you Paid with a Card, call them and start there buddy. That's why I try to buy as close as possible, because if something like that would happen to me I would definitely make the trip.
Old 12-21-2015 | 08:51 AM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
Contact Autofarm Porsche Specialists in the UK. They offer sleeve and install services on Porsche. They were one of the first service shops in the world to offer motor building options, sleeving and such of the early 996 motors. They, I'm sure could advise you, if you have junk or if the sleeves you have are usable. I have received new sleeves before that have had rust inside and out. The outside was was the biggest deal as it changed the OD and would make for a tighter interference on the press. A glass beading or scotchbright scrub was usually all that was needed. It ID would get bored so it was of little concern. These look prebored and fit so things are a bit different.
Old 12-21-2015 | 09:52 AM
Macster's Avatar
Precision shim stock was quite common when I was a machinist. Granted this was more years back than I care to remember but the need for shim stock never goes away...
Shimming isn't needed if the cylinders have not yet been bored for the sleeves. The sleeves would be chucked up and a skim cut taken to remove the damage and keep the finish. (Years ago when I was machining up some large pipe flanges -- by large I mean the pipe diameters were several feet in diameter and the flanges were inches thick - the pipe was for some kind of wind tunnel that was going to be used to test instruments under the conditions expected on Venus or Mercury (this was for NASA/AMES) -- the finish callout on the flange face was critical as it was to ensure the gasket between two mating flanges would not fail under the extreme pressure (we tested the unit to 900PSI) and temperature at which the unit would experience in use.)
The shortened (by just a few thousands of an inch) sleeves then would just require a slightly shallower bore to ensure the top of the sleeve was flush with the deck of the block.
Old 12-21-2015 | 11:35 AM
BLKMGK's Avatar
These engines use slip-in sleeves, no boring required to insert although rust on the outside could interfere with slipping it in. There's a good thread on Renntech from bbi showing the assembly of an engine with a GT3 case that would be informative.
Old 12-21-2015 | 12:22 PM
e8_pack's Avatar
e8_pack is a jewel in the roughe8_pack is a jewel in the roughe8_pack is a jewel in the roughe8_pack is a jewel in the rough
I highlighted the rust but initially but I felt confident I could clean them up ok, however I didn't notice the marks in the gasket areas. I have spoken to vivid and they were very helpful asking me to send the pics and they would sort it out, so hopefully it will be taken care of without much trouble. I have checked the original pics I sent and the ones on the ad and some of the marks are clearly visible so they have always been there, but you have to be looking very closely for them.
awfilms
01-20-2016 12:01 PM
Blazed
12-23-2015 09:57 AM
Quick Reply: Head Gasket sealing area - sleeves
