Custom airfilter box vs fenderwell airfilters
Hi guys,
Planning to go MAFless and upgrade my turbo intake piping.
To go with my (almost) 700hp plans.
Trying to decide between:
A)
Custom fiberglass airfilter box
Stock location
Cold air feed from GT2 wing (same as the standard box)
Two high flow dual cone filter
3 inch piping from each end of the
So really much like the nice 997 options available
Have made an early prototype and looks like I could make that work.
Downside is that I have to cut +3 inch holes next to the existing intercooler -> y-pipe hose. To allow the piping to run directly from airfilter box out next to intercooler duct.
B)
Filters in the fenderwells
Will place them next to intercooler ducts WITHOUT cutting ducts.
For me it is not an option to cut ducts. I know many high hp guys do this but I dont like that route.
I am looking for a nice air inlet setup that doesnt sacrifice airflow through intercoolers. Must be possible.
I like the short piping involved in this setup.
Downside is that it is hard to find a good solution for cold air feed..
Thinking about making a fiberglass airbox to fit behind IC duct.
But not sure where/how to pick up cold air flow..
Maybe put a duct/intake down low rear corner.
Has anyone experimentet with that?
Not paying $1000+ and dropping/lowering motor to install any of the available pipe kits.
Would rather have some fun in the garage making my own setup
A)
Stock location
B)
one of the main goals to running mafless is it allows for a 3" y pipe setup to be run from the i/c to the t/b. having this won't allow much in the way of a stock style airbag to fit.
this leaves fender wells. the issue there is the tight space between the turbo and the fender well. the piping being 2.5" tends to rub on the wheels as the suspension moves up and down. also its a major pia to get to the filters to clean them.
so the last option is filters off the turbos. mount a filter. then design a shield that covers the filter on the tire side possibly add some old school louvers on the tire side to allow air in but deflect any water. shortest route most air possible
Steve is right. Getting a 3" even flowing ypipe in is a big benifit of doing it all properly
If you want to stay with an airfilter in the rear, then I would go the full 997 route. Use a 997 air box, 3" piping, with holes in the side like Emre's cars down to the airfilter. But, you would also have to go with a ypipe like the 997 and tweak the AC lines.
Your best bet is either filter on the turbo or fender intakes. clean them everytime you do the plugs.
What turbos / boost / fuel are you going to be running? That may not be the weak link in your setup.
I run a 2.5 fender intake which was a pain to build and design, but I drive my car and possibly could get stuck in the rain. I had a friend lock an engine up from water from filters on turbos... Just depends on what your goals are.
Hi guys,
A)
Stock location
B)
A)
Stock location
B)
Good point on the 3 inch y-pipe.
I believe it isnt needed for my current hp goal but I will try and see if I can design the airfilter box so it allows 3 inch y-pipe. For future plans :-)
Should be possible.
Will look into that first and if it turns out to be too tight, I will hvae to look at a fender setup.
Should be possible.
Do we have any photos of this setup?
I had/still have some 3" fender intakes that I made that didn't rub, I do run 12mm spacers though and I did have to fabricate some on the pass. side intake. I removed them so I could run the top IC ducting again. With 2.5" pipe and smaller filters...I could have still run the top IC ducting but just got lazy and didn't want to do it all over. I now run the filters directly off the turbo method with some pre-filters to help keep water out.
I'd like to see your air box design though!!!
I'd go this route. Cold air intake is not an issue and the install is clean and OEM-like. The biggest PITA is the fuel cooler - but this is def not more work than a custom fender well setup. There are a couple of threads on using the 997 airbox in a 996.
Just use 997's fuel cooler and ta-daa, problem solved. BTDT.
Finally have time to work on the 996tt again.
Havent been able to find posts about 997tt airfilter box in 996tt, would like to know more about that solution.
Fx can the turbo inlet piping also be used from 997tt..?
Played around with the prototype airbox and decided it was taking up too much space to allow for a decent y-pipe.
This prototype was designed around a set of BMC dual cone filters, and would allow plenty of cold air flow.
I have paused the project for now and went with the classic fenderwell filters instead.
I have now recieved a 3" y-pipe and with that lying around in garage I can better try and design the airbox to allow room for y-pipe.
So at some point, when time allows, I will probably continue this little project.
PrMike
02-12-2016 11:32 AM
mateush
12-30-2015 04:29 PM
Southpaw07
12-16-2015 06:02 PM
PrMike
12-09-2015 02:06 AM
