Is this 996TT Viscous Coupling or a 997TT?
Old 02-19-2016, 06:24 AM
OK51MON's Avatar
OK51MON is infamous around these parts
Exclamation Is this 996TT Viscous Coupling or a 997TT?
Im sure this is a 997TT VC and drive shaft? Can any one comment please?
The reason I ask is a someone approached me wanting to sell on so I wanted to be sure.
What I think a 996TT VC and drive shaft look like;
Any input greatly appreciated.
Old 02-19-2016, 07:49 AM
Macster's Avatar
My WAG is it looks like a 996 Turbo front diff, viscous coupling with cardan shaft.
The 997 coupling is a wet clutch pack with the amount of engagement controlled by the DME. Thus I would expect to see some kind of a wiring harness connector on the diff/clutch pack housing.
Should be some part numbers on the hardware some place. Find them and write them down and google them.
Old 02-19-2016, 08:29 AM
OK51MON's Avatar
If the above is for a 996TT why do they look different?
Old 02-19-2016, 11:02 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
Looks like a 996 front diff with a 997 torque tube assembly bolted up to it. Not sure if thats an upgrade or if Porsche made any like that or why it would be done
Like mentioned above, if it is 997 front diff, it would have a wiring harness coming out right after the section where the 2 halves of the assembly bolt together.
Old 02-23-2016, 08:10 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
top one with orange red is for non-turbo wont work for ya
Old 02-24-2016, 12:26 PM
it may be 997 C4s ... it used 996 style viscous coupling.
check to see if it has a small electric plug on it for the diff control.... that will be your answer.
#TeamAIM
Old 02-24-2016, 01:09 PM
OK51MON's Avatar
the part number matches up to a turbo model
Old 02-24-2016, 07:22 PM
Porschetech3's Avatar
Porschetech3 is infamous around these partsPorschetech3 is infamous around these parts
If the part number matches a Turbo..go by the part number..BTW what is the part number? Do not go by the housing design, it is an updated housing, I made the parts department verify this once when I was doing a replacement years ago on a 996T that originally had the smooth type and the replacement was the skeleton type.
Old 02-25-2016, 08:30 PM
then it would be a 997.1tt diff, and have the Electrical harness sticking out
acs370
05-14-2020 03:26 PM
KA 997TT
McLaren
05-17-2016 07:04 PM
nitrorocket
02-18-2016 08:52 AM
Gotgolf52
02-15-2016 05:46 PM
Webspoke
02-14-2016 08:43 PM
Quick Reply: Is this 996TT Viscous Coupling or a 997TT?
