What is the best K16 hybrid combo to go with?
#46
Dont let these little guys destroy the narrative
https://www.6speedonline.com/forums/...-put-test.html
#47
Lol cheers Earl. And I even made it clear that it was on a built high compression motor running ethanol and standalone tuning. Because I know it's on the extreme side but wanted to share. I can appreciate everyone's passion. I won't argue because it will continue forever. Just state my 20+ year facts and keep my lines open. It's not always super cut and dry.
Sambo I normally don't argue a lot either but on this I will. Thanks for sharing thay one earl, had not seen thay one yet.
#48
that made 790whp on your 16/68 which is a fp designed 20g and that was without intercoolers and at only 25psi, imagine if they turned it up to 30. (Yes it wad a 3.8 motor though) They flow a lot.
There setup is something that you will not run probably unless you want to spend high dollar money. Pro efi, high compression motor, e85, 3.8 liter lots of wheel spin. Plus it was not on a mustang dyno which doesnt flame there numbers and those are corrected numbers not uncorrected.
20g will not work and until it does its pointless. I had the 24/71 turbos they made 600plus awhp at 20psi. To get to 900awhp it would not happen. Once we see it then we will all believe it but most of us move on from small turbos to bigger ones. We want more pull uptop.
#49
600awhp at 20 psi, I'm going to guess on 93 octane and stock ecu.
#50
So now your back pedaling saying it's not possible on a porsche motor but here it is fone, just more expensive to do it. This goes back to what I said earlier about the setup and restrictions through the whole car. Also fuel and ecu. A stock ecu hugely limits you compared to a standalone and you have to run race gas or e85.
#51
#52
Not on stock k16s but 16g Billets yes thats about right for power at that boost. We took my power out so my rods last.
#55
My cat is rwd so now does that mean whatever my number are it won't count?
#56
Comp will be 48.5/68mm
Turbine is 56/49
#58
will just wait for your turbo build you will be pretty upset when you dont get even close.
#59
I'll post up my numbers when mine is done with is on the lowest reading mustang dyno I've ever been on as well.
#60
what is the HP/boost limitations of the stock block? I would imagine a pair of hybrid k16s can meet that. unless the OP is building the block, does it make sense to go with anything larger than a k16hybrid?
