Camber Plate Bushing Recommendations
#31
Ah okay, I was looking and they offered two different durometers and I thought the stiffer than stock one would be a good upgrade while avoiding potential harshness from monoballs..
#35
If this works out, it could be a very nice option. You get the advantage of the monoball, with the fitment of the stock hat. It's also about 60% of the cost aftermarket or stock camber plates.
Later, Steve
Later, Steve
#36
For sure! I may have given them a shot at that price (had I known about it, lol). Worst case scenario, if not happy sell the "rebuilt" plates. I'm guessing you will likely be happy with them since from what I've read the diff in nvh is minimal. Keep us posted!
#37
just another option for you guys a little cheaper then Elephant.
https://www.stomskiracing.com/produc...r-plates-sr121
#38
I received the monoball cartridges today. They are very nice quality.
There's a threaded nut to allow for installation and to get everything tight. There is also a snap-ring (which I assume is a safety measure), that is nice and tight and shouldn't give any issue with rattling. The ball is also sealed on both sides.
I'll let everyone know how the installation goes, but here a few pictures of the parts.
Later, Steve
Later, Steve
#41
You cut out the old rubber center with a hole saw. I believe I'll be able to get the bushing in with my vise. The hex nuts on top and bottom are really what's holding the bushing in place.
Later, Steve
Later, Steve
#44
Okay, here's the process I use.
I won't go into removing the camber plates, it's already been documented.
The center of my camber plates were completely worn out, so it was easy to push the center out by hand.
I drilled out the center with a 1 5/8' hole saw.
Here's the part after drilling out the rubber.
Afterwards, I took a small chisel and cut out a little more rubber from the center. Trust me, if you don't do this, you won't get the monoball cartridge in without a press.
You could probably complete the install at this point, but I wanted it to look more finished. I used a wire brush to clean out the remaining rubber. FYI the wires were a lot longer when I started.
Here's a camber plate after removing the rubber.
A little bit a paint and they were ready for the monoball cartridge install.
Finally I used some sockets and a vice to push the cartridges into the camber plates (sorry for the poor lighting).
I'm out of town this weekend, but hopefully I get everything back together next weekend.
Later, Steve
Later, Steve
#45
Very nice. I like that you kept going and removed all the rubber, not just the center. The finished product looks very professional. Can't wait for the install and first impressions.
I on the other hand, decided to go with OEM top mounts after many weeks of going back and forth.
