Dual Mass Flywheel failing.
So Murphy's law, I just finished doing a bunch of mods that included a new Sachs 2.5 clutch... 300 miles later, I'm pretty sure my DMFW is starting to fail. I'm having chartering/vibration when in reverse at idle speeds and the same thing on down shifts if I don't blip the throttle to keep the revs up. Hind site, I probably should have put a new one in while I was at it but my car only had 40kmiles on it so I figured it would be OK. My wife's 996 40th Anniversary didn't show DMFW issues till around 90k miles.
Question:
Other than the annoyance factor when I back into my garage, are there more issues/risk to come or is this going to be the extent of the issues relating to a failing DMFW?
Are there any risks with just living with it as is? The vibration at low speeds doesn't bother me as of now.
Question:
Question:
Question:
Reverse gear is not as low as first. 2.875:1 vs. 3.818:1. Thus using just idle RPMs to back the car up can have the engine protesting.
Even with as far as I know a perfectly fine DMF I always have to rev match when downshifting if RPMs are elevated.
When you installed the Sachs clutch did you replace the clutch control shaft needle bearings? They can fail and cause clutch engagement issues.
Question:
Question:
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Sorry to interrupt the discussion, here, but I saw magoochi's comment about his wife's 40th (I've got one, too). I shot you a PM if you don't mind checking it when you have time. Thanks much.
Al Norton
04-02-2016 11:29 AM
Drifter911
03-28-2016 08:12 PM
