No boost p0238 p1136 p300 p301-303
Old 04-20-2016 | 10:46 AM
EURASIAN's Avatar
EURASIAN is infamous around these parts
Need some help, I don't post much but I read a lot and I cant seem to find anything on this. Working on 2004 996tt just rebuilt the engine due to # 6 rod failure. I can't get it to make boost. Car is modded with k24 turbos, AP y-pipe,5 bar fuel press regulator, Ap air box and fabspeed exhaust, AP diverter valves, Pauter rods. I am a 20yr Porsche tech and have built many engines. All that said this is where I'm at.
No codes at idle, Turbos spin freely waste gates are closed, Passes both smoke and pressure test @20psi. Since it is known that tuned cars eat maf I have swapped with a known good unit = boost sometimes if ease into throttle. Also would make boost high rpm but not clean kinda broken up. Threw p1508 in limp mode until clear code. Swap MAP = no change, Check diverter valves closed like they are suppose to be , even block off = no boost. Swap p75 = no boost. Replace spark plugs coil packs look good = no boost.
Im thinking this maybe of some issue camshaft deviation b2 is -6 while b1 is 2ish. Actual angle is 0 at idle and both climb to 30deg when reved. All seems to be fine. I just remember that on 7.8dme that the threshold is 5deg on NA cars not sure if it applies to turbo cars. My problem is that its b2 that is -6 and misfires are on b1. I have yet to have a Cam retard code. I know it is probably something simple Im just running out of ideas and about to pull engine and go over every detail.
Old 04-20-2016 | 10:54 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
I just went through some camshaft/misfire issues on my car.
I'll have to look at my data when I get home tonight, but I don't think your camshaft deviation and actual values are a problem. Post the numbers at dead cold start after sitting overnight for deviations/actual/rpm and again after 5 mins idle, and again after a drive to be sure and I will cross-check, but I think mine are in the same ballpark as you though.
Check your variocam solenoid brackets that are in the same area as the coilpacks, they become brittle and break and can cause misfire codes as the actuator/solenoid can't stay seated in the cylinder head. I've read that they will cause errors for misfires on bank opposite of the cracked bracket.
Old 04-20-2016 | 11:03 AM
GT3 Chuck's Avatar
Administrator
You should post this in the technical info forum and get an answer from a Porsche Master engine builder
Old 04-20-2016 | 12:24 PM
EURASIAN's Avatar
Seattleturbo, thanks for help, Ill log data tonight with the piwis. I looked close at the brackets when I put it together but I'm not rulling anything out I'll look again. Thanks
Old 04-21-2016 | 01:33 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Thise codes are a sign of a massive boost leak. What did u touch when you were working on the car? Have you messed with your throttle body?
Old 04-21-2016 | 02:43 PM
EURASIAN's Avatar
996tt550, Pressure test intake full system to 20psi = no leak, I have not touched the throttle body minus doing a re-calibration for p1508 code.
thread re-posted in technical area
https://www.6speedonline.com/forums/...301-303-a.html
Old 04-21-2016 | 02:58 PM
996tt550hp's Avatar
I had this issue with the p1508 and my throttle body was dirty it didnt look it but i cleaned it and put a new gasket on and i never had it again.
Throttle body or maf sensor.
Old 04-21-2016 | 05:38 PM
BLKMGK's Avatar
Have you tested from the turbo outlet? If you test just at the intake by the filter box you won't detect a BOV stuck open I believe.
Old 04-21-2016 | 06:42 PM
EURASIAN's Avatar
You are correct. I pulled the bov and tested separately. I even took them off and plugged the holes
Old 04-21-2016 | 07:33 PM
BLKMGK's Avatar
What are you doing for intake piping? One member recently had his collapse (!) and the result was low boost, is this possible? Does the car struggle to breathe? Fuel pressure good? Fuel filter new?
Old 04-22-2016 | 03:59 AM
And996tt's Avatar
And996tt has a spectacular aura aboutAnd996tt has a spectacular aura about
https://www.6speedonline.com/forums/...minutes-2.html
This thread has some info on what happens when the cam timing is set wrong, may be of some use
Old 04-22-2016 | 06:57 AM
EURASIAN's Avatar
And996tt, Thanks for thread link, I studied it before posting. BLKMGK, I don't think that's a problem but I'll check out all the intake plumbing and make sure.
Old 04-22-2016 | 05:09 PM
BLKMGK's Avatar
Honestly it seems like a long shot to me too but others have seen it and it did solve a problem for someone recently. If the charge piping is solid, the turbos spin properly, and the intake side good then there's not a whole lot left except throttlebody is there?
Old 04-25-2016 | 07:51 AM
EURASIAN's Avatar
IDK , Ill put it on my list. I kinda stepped away to take a breath. I'll start back on it this afternoon.Thanks for help
Wealth Manager
08-08-2016 05:13 PM
P997S
05-04-2016 01:03 PM
tromero
04-04-2016 06:16 AM
pabafree1995
03-24-2016 05:09 PM
Edreamsz
03-23-2016 07:52 AM
Quick Reply: No boost p0238 p1136 p300 p301-303
