Transmission removal process difference - C2 v. TT
Old 04-26-2016 | 11:46 AM
saline's Avatar
saline is infamous around these parts
There is a great article for the transmission removal of a C2, but I'm wondering, other than the additional removal of the front drive shaft, is there a difference in the removal process. I know the engines are different, but I don't know how that might effect the clutch or transmission mounting in a TT.
FYI, here is link to that process. http://www.c-speedr.com/howto/996rms/rms1.php
Old 04-26-2016 | 12:21 PM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
The gearbox is different also, it sits only with 4 bolts to the engine.
Also you must remove the clutch slave from on top of the gearbox, the gear fork hinge (which is a pain in the ***), the starter and the front driveshaft as you mentioned.
There are several 996tt DIY's available in here if you do a litle search.
DOPE_996tt
03-26-2017 06:42 PM
feeltherush
08-15-2016 06:52 AM
oddjob142
04-14-2016 06:55 PM
Al Norton
04-13-2016 03:54 PM
msgm1
04-13-2016 01:13 PM
