997Cup steering wheel install....
Old 06-24-2016 | 05:54 PM
32krazy!'s Avatar
this is with 2 20mm spacers
  #32
Old 06-24-2016 | 05:57 PM
pwdrhound's Avatar
The Rothsport hub is 2" if I recall. If using the Rothsport hub you need the QD to get correct spacing. Without a QD you'd need to use the longer Momo hub. I highly recommend the QD however. Even if you don't want to mess with the wiring, I'd install the factory 997Cup QD which does dot have the connector. It's also cheaper at $500.
Here is the distance of my set up. It places the wheel about 3/4" closer to the driver than OEM for a more appropriate track driving position. That's with one 20mm spacer machined down to 10mm. If both were machined to 10mm the wheel would be close to stock. I'm 5'10".
Steve's set up as shown above will have the wheel about 1.25" closer than stock. Keep in mind that the closer you place the wheel the longer away the turn signals will be. About 1" or so is still comfortable for normal hands.
[url=https://flic.kr/p/HMN13S]
  #33
Old 06-24-2016 | 07:49 PM
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
As always, thanks all!
  #34
Old 06-26-2016 | 02:51 PM
ccjimmyb's Avatar
ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !
If I can ever get mine buttoned up this will be next right after the rotors.
  #35
Old 08-28-2016 | 03:52 PM
32krazy!'s Avatar
john did you ever find any extra 90* pieces of c/f?
  #36
Old 08-28-2016 | 04:46 PM
Jferrante's Avatar
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
Nice writeup - I am looking to just go OMP wheel with the hub. Sounds like you lose the horn in this application?
  #37
Old 08-28-2016 | 05:08 PM
32krazy!'s Avatar
see the c/f piece behind the wheel? theres horn buttons on them
  #38
Old 08-28-2016 | 06:48 PM
pwdrhound's Avatar
I don't have any of the 90º pieces left Steve. I got them from my race shop. I'll find out where they got them from. I'll be there on Tuesday.
  #39
Old 08-28-2016 | 06:50 PM
pwdrhound's Avatar
The horn buttons are the red buttons on the 997Cup wheel. The buttons on the CF plate are the MoTec control buttons.
  #40
Old 08-28-2016 | 07:11 PM
Jferrante's Avatar
got it thanks guys
  #41
Old 08-29-2016 | 08:04 AM
Jferrante's Avatar
...last question on this - what is everyone using to bypass the airbag light on aftermarket wheels now? Resistor or is there still a Porsche part that they use on the cup cars? (read that in another forum but wasnt 996 specific.)
  #42
Old 08-29-2016 | 10:33 AM
pwdrhound's Avatar
Simple resistor does the trick...
  #43
pwdrhound's Avatar
There you go Steve...
http://dragonplate.com/ecart/categories.asp?cID=274
  #44
Old 08-29-2016 | 10:36 AM
Jferrante's Avatar
cheers!
  #45
Old 08-29-2016 | 06:36 PM
32krazy!'s Avatar
cheers!
send me your address i have extras
