997Cup steering wheel install....
Old 06-04-2016 | 01:10 AM
pwdrhound's Avatar
Finally getting around to posting up some pics of my steering wheel set up. Ever since I've been running the Recaro Profi Spa seats I've been a bit nervous about the ability to get out for the car in case of an accident. The super light Profi Spa Carbon Kevlar seats are phenomenal and have very high thigh bolsters that keep you pinned in place. The only problem is the fact that there is very little room to squeeze your legs in between the steering wheel and seat on entry and exit. In case of a bad accident it could be very difficult if not impossible to get out of the car with the stock steering wheel. I also wanted to get rid of the airbag as I don't want it exploding in my face while wearing harnesses and a helmet.
My car came with the RUF steering wheel which is 365mm compared to the stock 380mm Porsche wheel. After looking at a bunch of options, I decided to replace the RUF wheel with a Porsche Motorsport 997Cup steering wheel. This wheel is light as a feather since it has an aluminum frame and is covered in alcantara. It has a 320mm diameter which makes it very small making for vary fast steering inputs and corrections. The feel of this steering wheel is absolutely amazing. It changes the whole feel of the car. The wheel comes with two button which can be used for various functions. I chose to have both operate the horn as the car still sees very limited street use. I also wanted to have my MoTec control buttons installed on the steering wheel allowing easy on the fly control of the MoTec dash display. The other key element, and the whole reason for doing this, is that I wanted to have is a quick disconnect on the steering wheel to allow for quick removal for fast egress in case of an accident. This also makes a great anti theft device as you can remove the steering wheel and take it home with you. We initially decided to use the factory 997Cup quick disconnect as they are the best QDs on the market. The traditional set up on a QD wheel is to run a curly cord which allows one to remove the steering wheel but it stays tethered to the car as the curly cord carries the cables for the various control that are on the steering wheel including the horn. The traditional curly cord which hangs below the steering column is a real pain in the **** as it naturally gets tangled up in the turn signal stalks as the wheel is rotated during tight turns. Race cars don't have turn or wiper stalks and their steering angles are much more limited so the curly cord is much less of on issue for them. There had to be a better way.
[url=https://flic.kr/p/HL55YJ]
After consultation with Chris Cervelli (Cervelli Technical Service), we decided to take it up a notch and install a really trick QD set up which would bypass and eliminate the traditional external curly cord while retaining the horn and MoTec functions and having a fully detachable steering wheel. Once again, Chris pulled out all the stops in making this happen.
After looking at all of the options, we sourced a QD that is manufactured by the German manufacturer that makes the factory QD for Porsche Motorsport. They also make QDs and other parts for F1 and other top level motorsports segments. The difference in their top of the line offering, while physically the same as the Porsche Motorsport QD, is the fact that they add a 23 pin electrical connector which allows you to run 23 functions through the QD with the use of a built in trick connector. The QD itself is very beefy with heavy duty spring loaded locking pins. Compared to the traditional off the shelf QD offering like Rothsport, Momo, and Rennline, well, there is actually no comparison. It's like comparing a Rolex to a Timex. The locking action is very positive with zero play. The quick release function is tight and solid. The other QDs feel downright Mickey Mouse when compared side by side. Even though the QD has a very solid feel, every bit of extra material is machined away by the manufacturer to make the QD feather light. The other benefit of this QD is the fact that it is very slim, about 3/4" slimmer than the other offerings. This is important so that it does not place the steering wheel too far out (with this set up the steering wheel is 3/4" closer to the driver than the stock wheel which worked out perfect for me). I also fabricated a carbon fiber plate that is bolted on the backside of the steering wheel so that the MoTec control buttons can be cleanly attached. A couple of QD spacers were used between the steering wheel /QD / hub itself to allow the wiring room to tuck away with room to spare. One of the spacers was machined down to get the perfect wheel distance I wanted. The full length spacer would be used for taller drivers.
[url=https://flic.kr/p/HiVhBc]
[url=https://flic.kr/p/GTf8go]
[url=https://flic.kr/p/HL4HJE]
[url=https://flic.kr/p/HP6mMr]
The last thing we needed was the hub itself. We ended up using a Rothsport aluminum hub. This a nicely finished lightweight CNC part. The only issue is the fact that it does not have the turn signal cancel tab that is normally a part of the OEM clock spring (which is removed). After a little head scratching, I ended up making the tab out of aluminum 1/16"x3/4" stock. I cut a piece down to size and bent it to the proper radius by using a 24MM socket and worm clamps to provide the bending force. I heated the aluminum with a blow torch to make it softer and more easily pliable. After the tab was shaped, I used a belt sander to thin it out at the edges to make it a seamless transition with the hub. The tab and the area on the hub where the tab is attached was roughed up with a dremel and the two parts were mated with JB Weld.
[url=https://flic.kr/p/HGK1tn]
[url=https://flic.kr/p/HP6AjM]
[url=https://flic.kr/p/HGJZZr]
[url=https://flic.kr/p/HL5117]
After Chris performed his behind the scenes trick wiring, we were ready to get everything installed. A curly cord was used as part of the wiring. It is fed though a custom made carbon plate (that neatly caps the front side of the control column) and is fed through the back side of the hub where a hole was drilled. There is enough room in the back of the Rothsport hub to allow enough slack so that the curly cord can stretch as the steering wheel is rotated during steering inputs. A resistor was also used to get rid of the airbag light. In the end the project truly exceeded my expectations, which generally happens when Chris works his magic. For those that may be interested in a similar set up, I have a couple of these QDs on hand as I purchased a few extras.
[url=https://flic.kr/p/HoDQT7]
Additionally, for those wondering, the factory RUF steering wheel with hub weighted in at 9 lbs 10 oz. The 997Cup wheel with the QD and hub including all wiring weighs in at 3 lbs 6 oz. This is a net saving of 6 lbs 4 oz. Not bad. A stock Porsche steering wheel is even heavier than the RUF wheel so the saving would be closer to 7 lbs.
And the finished product....
[url=https://flic.kr/p/HGJArz]
[url=https://flic.kr/p/GTpsYF]
Old 06-04-2016 | 04:48 AM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
Wow, that is awesome. Amazingly clean install.
Old 06-04-2016 | 08:13 AM
ccjimmyb's Avatar
ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !
Looks sweet.
Old 06-04-2016 | 08:45 AM
BLKMGK's Avatar
Looks really nice, liking the shift light behind the hood too! I may have to steal that shift light idea :-) I like that you've kept it so streetable and it sounds like this was a really good idea safety wise, hope you never have to call upon it!
Old 06-04-2016 | 01:23 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
PM me John. I just did a similar install and could find where to purchase the QR Hub. I would be interested in one
Also - glad you figured out how to make the rothsport Steering hub cancel the indicators. I what thinking of something similar. This will solve my problem.
Old 06-04-2016 | 01:39 PM
32krazy!'s Avatar
ok john now i need the qd w/ the pin setup! exactly what i was looking for to hide the wires. would a sparco hub work with this and allow cancellation?
Old 06-04-2016 | 02:02 PM
pwdrhound's Avatar
PM sent..
Old 06-04-2016 | 02:14 PM
pwdrhound's Avatar
Hey Steve. The Sparco hub has the turn signal cancel tab built in so yes, that will work. I'm not sure however how you can wire the horn with the Sparco hub without running an external curly cord. The Sparco hub does not have the relief on the backside of it like the Rothsport. You need the relief on the backside to hide the curly cord. We grounded the horn directly off the Rothsport hub by the way. The Rothsport hub is required in order to run this set up as detailed in this thread.
The QD is $695. I include all pins for the connectors including the pinning tool. The QD spacers are $60 each. You will need two when using the Rothsport hub. You will need someone that can wire everything up. With just a horn it is pretty straight forward. My set up was a bit more complex as we had to integrate the Motec control buttons. What we used is a simple curly cord telephone cord that I bought at Target in the electronics section for $5. These are very flexible and nearly indestructible. The telephone cord has 5 internal wires so you can run the horn with it plus a couple of other functions if you'd like. Another good curly cord option would be one off of a cell phone charger for example. Those are very durable also. Call me if you have any questions.
Old 06-04-2016 | 03:45 PM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
Perfect John! I have a feeling I would do the 996 Cup wheel some day, as a larger wheel it may give better view of the original gauges I still need to see, however 996 Cup wheel does look something from a 964/993 era vs. the newer 997 Cup wheel.
I'm actually most interested in the 991 Cup wheel, that looks kind of the best for my eye. Why did you not opt for that? You even sold yours and chose 997 Cup wheel instead?
It would be perfect to see a project where the additional CF plate with the buttons would work in our cars
Old 06-04-2016 | 04:14 PM
pwdrhound's Avatar
Hi Kai,
I didn't need the flat bottom of the 991 wheel and I wanted a wheel that was as flat as possible as I was not 100% sure of which spacers I would have to use with the wheel or which QD I was going to use. Dimensionally the 997 and 991 wheels are identical at 320mm but the 991 wheel has a very slight dish to it, maybe 1/4" more than the 997. It boils down to looks basically and I prefer the 997 version. The 997 wheel is also a couple of ounces lighter, not that that matters. That plate you see on the 991 cup wheel in your picture is sold by Porsche motorsport at almost $1000. Yeah, funny. I made my own for a $10 in CF cost.
I am not a huge fan of the 996Cup wheels. They are 350 and have almost 3" of dish which places the wheel very close to the body when used with a QD. We run these in our Spec Boxsters. My team mates are all taller and like the 996Cup wheel so that is what we use but it gives you a different driving position as you can see below. The 997cup set up I have now places the steering wheel 3/4" closer to the body than the stock wheel. When I pull the whole column all the way out its perfect for me.
[url=https://flic.kr/p/GVbZUT]
Old 06-04-2016 | 04:20 PM
Kaizu's Avatar
Ok thanks for info! Btw. The quote you use in your signature makes me always grin when I read it and the associated mod list...
Old 06-04-2016 | 08:41 PM
pwdrhound's Avatar
Yeah, I guess I've checked a few boxes on the option list along the way... Lol
Old 06-05-2016 | 08:35 AM
32krazy!'s Avatar
are the spacers the gold piece i see or the black piece i see? or both?
Old 06-05-2016 | 10:37 AM
b4stiTTS's Avatar
b4stiTTS has a spectacular aura aboutb4stiTTS has a spectacular aura about
very nice Job John! Looks very n1 and clean
Old 06-05-2016 | 11:26 AM
pwdrhound's Avatar
Hey Steve. The gold piece is the quick release. When you pull on it, the wheel disconnects. The spacer is what you see mounted between the QD and the wheel itself. I have a full thickness 20mm spacer there and than a 10mm spacer between the hub and the QD. You have to have the spacers there in order to have room of the wires to tuck away. This is the spacer:
[url=https://flic.kr/p/GWKoAz]
