Hesitation/miss under load
Old 06-07-2016 | 08:03 PM
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
I have go thru the hesitation issue 5 years ago, it was fine to drive, but once you get into boost, around 5000rpm it would backfire and hestitated. It was a real painful investigation for 3 months.
As per advised, coils and plugs(replaced not less than 3 times during the period), MAF old and new interchange at the road side. Header, intercooler hoses and almost all vacuum hoses were replaced.
Finally, it was the first thing we checked, the fuel pump, it just didnt totally gone, but in centain rpm it didnt provide enough fueling and it wasnt happening all the time...
  #32
Old 06-07-2016 | 09:40 PM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
Will replace plugs and coils shortly and will keep this in mind if the problem persists...thank you for sharing your experience.
  #33
Old 06-10-2016 | 12:35 AM
bushrat's Avatar
Originally Posted by bushrat
2004 996tt....have a miss/hesitation under load .Engine idles smooth and runs great until it starts to build boost under a hard pull, also makes a strange noise. Thought maybe coils or plugs but check engine light does not come on. 85000 kms (53000 miles) on engine. Something to do with the turbo system??? Any input would be greatly appreciated.
Well...here you have it. Had a friend hook up an analyzer to the OBD port then took the car out on the highway. Within a few hundred yards most cylinders took their turn misfiring. New plugs and coils being installed next week. Suspect I will see a major improvement in performance.
  #34
Old 06-10-2016 | 07:54 AM
'02996ttx50's Avatar
yep,
plugs n coils, plugs n coils etc.
gl w it. probably the fix!
  #35
Old 06-24-2016 | 04:13 PM
bushrat's Avatar
Changed out plugs and coils... plug electrodes all worn flat on both sides leaving a .045 gap on each side. Found 8 ounces of oil in the left intercooler.....off to the repair shop it goes :-(
  #36
Old 06-25-2016 | 02:47 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
That gap is way to much for plugs.
  #37
Old 06-25-2016 | 05:45 AM
agree. .027 is perfect.
  #38
Old 06-25-2016 | 06:32 AM
32krazy!'s Avatar
he isnt saying thats what the gap originally rather thats what the gap was when pulled. the plugs are worn down on both sides according to the op
  #39
Old 06-25-2016 | 09:11 AM
bushrat's Avatar
Bought the car in January. Previous owner kept no records and likely never changed the plugs or coils. Figure oil in intercooler coming from bad seal in turbo so removed the turbo and sent it off for a reseal.
Wheel Dynamics
07-01-2016 09:48 AM
flewis763
06-25-2016 05:54 AM
charlie1
04-12-2016 10:35 AM
350ZR
04-02-2016 11:04 AM
Quick Reply: Hesitation/miss under load
