Rennkit - Spoiler hydraulic solution
#31
Planning on redoing it and see what happens
#32
#33
OK Im just back from the track 2hrs of fun where the wing performed perfectly at top speeds of 230kph, im hoping ill test over 300kph tonight.
Im very happy I finally decided to buy Daves rams.
Dave refunded the cost of the rubber boots after I cut them off.
I'll now write and post a install thread with pics.
Cheers,
Tim
Cheers,
Tim
#34
Well, after a couple of days I've installed my 4" fast action eRam's so I figured I'd come on and share my thoughts:
Issues I had during install:
1) eRams went up and then not back down... of course this was my poor wiring thankfully the kit came with enough spare bits to fix my mistakes and get it all sorted.
2) eRams didn't fit around my EvoMS Airbox... until I realized I missed the part of the instructions where they can be adjusted then it fit perfectly.
3) Adapter wouldn't fit on my Misha Design Carbon Fiber wing... until I accepted that my screw driver wasn't big enough and I spent $10 on a massive but that I could put a wrench on then with a little soap to lube things up and they went on just fine.
4) Instructions were a little jumbled, which Dave fixed the same day I mentioned it so that's now a non-issue
Long story short three out of four issues were related to me and the forth one was that the instructions needed some editing which is done. Did a couple runs down the highway to see if they worked and it was nice to see the wing move faster, higher, more level and without a dang warning light.
On a side note, thanks to Dave who put up with a lot of crying from me and politely pointed out I just needed to do it properly and it would work fine.
So far it seems to be a good buy from a could vendor.
#35
Well, after a couple of days I've installed my 4" fast action eRam's so I figured I'd come on and share my thoughts: Issues I had during install: 1) eRams went up and then not back down... of course this was my poor wiring thankfully the kit came with enough spare bits to fix my mistakes and get it all sorted. 2) eRams didn't fit around my EvoMS Airbox... until I realized I missed the part of the instructions where they can be adjusted then it fit perfectly. 3) Adapter wouldn't fit on my Misha Design Carbon Fiber wing... until I accepted that my screw driver wasn't big enough and I spent $10 on a massive but that I could put a wrench on then with a little soap to lube things up and they went on just fine. 4) Instructions were a little jumbled, which Dave fixed the same day I mentioned it so that's now a non-issue Long story short three out of four issues were related to me and the forth one was that the instructions needed some editing which is done. Did a couple runs down the highway to see if they worked and it was nice to see the wing move faster, higher, more level and without a dang warning light. On a side note, thanks to Dave who put up with a lot of crying from me and politely pointed out I just needed to do it properly and it would work fine. So far it seems to be a good buy from a could vendor.
#37
Dave, any idea if this will fit a 997.1TT with Fabspeed intake? Any reason why i should go with a shorter unit? Can you post a picture of the trunk lid under side with eRams mounted?
And mind messaging me with your special bring for 4" high speed?
#38
PM Sent.
#39
Dave et al, I'm going to install a 997.1 TT decklid/wing on my 997.2 C4 (non-TT)
Related thread
https://www.6speedonline.com/forums/997/208788-turbo-wing-997-2-c2s-3.html#post4541702
Would You know if the eRams fit with a 997.2 airbox? I would think not. I prefer not to go the Fabspeed intake route. Thanks in advance!
Related thread
#41
#42
Dave et al, I'm going to install a 997.1 TT decklid/wing on my 997.2 C4 (non-TT) Related thread https://www.6speedonline.com/forums/...ml#post4541702 Would You know if the eRams fit with a 997.2 airbox? I would think not. I prefer not to go the Fabspeed intake route. Thanks in advance!
#43
RTurbo rear wing looks great with the added height bro.
#45
1/4 Turn Wing Fastener
Hey gang, I'm back with a favor to ask. I need a set (or at least one) 1/4 turn wing fastener. It seems oddly familiar to a Dsuz fastener. I will buy it or pay for postage both ways or whatever - want to see if my shop can fab these for the 996 TT community. Please email me.
Thanks in advance!
Dave C
djcooper@RennKit.com
www.RennKit.com
Here is what it looks like:
Thanks in advance!
Dave C
www.RennKit.com
