Will 996 GT3 brakes bolt right on?
Old 07-17-2016 | 04:26 PM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
I'm thinking about upgrading the calipers and rotors and have been eyeballing 996 GT3 brake setups. Anyone done this before?
Old 07-17-2016 | 04:36 PM
32krazy!'s Avatar
rotors wont fit unless gt2/3 uprights are used. calipers are the same as 997 turbo
Old 07-17-2016 | 06:42 PM
BauerR's Avatar
Thanks for the info!
Old 07-17-2016 | 11:13 PM
BLKMGK's Avatar
Two different somewhat easy upgrades I know of - 350mm brakes which use stock calipers, spacers, and 997 rotors and 380mm brakes which are a bit more involved and require calipers as I recall. Bear in mind that 380mm will also likely not fit 18inch wheels, only some will fit. I've got a google spreadsheet with many of the part numbers, the spacers for 350mm are silly money if you buy them but fairly easy to make.
Old 07-18-2016 | 06:22 AM
BauerR's Avatar
Thanks, buddy!
I think I'm gonna go all in on the brake upgrade. Larger calipers and rotors. I have 19's so I should be good with clearance.
jetfuelonly
10
06-05-2018 12:04 AM
Drifter911
12-11-2016 11:38 PM
CBRacerX
03-28-2016 10:25 PM
RacerX
09-04-2003 10:24 AM
Quick Reply: Will 996 GT3 brakes bolt right on?
