Fault Codes- Please Help 996TT
Can anyone shed light on these? Running 100 Cell exhaust
Current Fault Codes
P0140
Factory Fault Code 12 - O2 sensor circuit
No activity detected
P0161
Factory Fault Code 374 - O2 sensor heater circuit
Could be signal implausible, open circuit, below limit, or above limit
P0136
P0156
Factory Fault Code 20 - O2 sensor circuit
Current Fault Codes
P0140
P0161
P0136
P0156
Current Fault Codes
P0140
P0161
P0136
P0156
Current Fault Codes
P0140
P0161
P0136
P0156
Possible fault cause:
Open circuit in signal wire or ground wire of O2 sensor
O2 sensor heating faulty.
P0161 - O2 sensor heating after TWC, Bank 2 - Open circuit.
Resistance of the O2 sensor heating too great.
Open circuit.
P0136 - O2 sensor after TWC, Bank 1 - signal implausible.
Short circuit to ground in signal wire.
Intercore short circuit.
P0156 - O2 sensor after TWC, Bank 2 -- signal implausible.
Each of the above error code has some tests to run to determine if the problem is with the sensor, its connector, the wiring harness, or the DME.
Given the errors are on both banks, with just the sensor after the TWC (three way converter), I'd hazard a guess you have an exhaust leak.
Did you just install an exhaust system?
As an aside it is very important the metal o-ring that seals the turbo to the exhaust is replaced whenever the turbo and exhaust are separated, as would be the case when plugs are changed.
