Turbo back exhaust installation advised needed
Hi there,
I've just purschased a used turbo back exhaust system for my 996 turbo and would like some advise on what items I need to get for the installation.
I'm thinking of getting new O2 lambda sensors rather than trying to reuse the existing ones installed on the original exhaust.
Believe I need to get 2 sealing ring gaskets that sit between the cats and turbos
Also I believe the original nuts and bolts that connect the cats to the turbos will be too rusted or perished to reuse and need to be changed.
What specific nuts and bolts do I need the porsche original items are too expensive for what they are - your advise guys would be greatly appreciated
You've got most of it correct. If I was doing it over again I would have replaced all 4 O2 sensors when I installed the exhaust. I ended up breaking both of the downstream O2s when I removed them from the factory exhaust. I picked up new high quality lock nuts from 034motorsport because they are smaller 10mm size and very high quality.
https://store.034motorsport.com/airc...m8-x-1-25.html
Pick up the Victor Reinz ring gaskets. Same as OEM, and much cheaper.
http://www.pelicanparts.com/More_Inf...111-215-70-M17
I also chewed up a couple of the studs during removal and just went to local ACE and picked up some new carburized steel automotive studs in the 1.25 metric thread pitch.
Good luck!!
Good luck!!
what brand of aftermarket exhaust are you going to install? i just purchased a 2002 turbo 39000 ,iles, tip, that has an AP ti system installed and i am interested in other owners opinions about sound any performance difference etc. my car has the IPD intake upgrade and ecu flash as well as new inter-coolers bigger turbos injectors so I am not be in the apples to apples category of sound comparison. thanks Robby H
JLnike
10-03-2016 11:53 AM
B8_RDC
09-13-2016 07:04 PM
ECS Tuning - BMW
BMW Vendor Classifieds
08-15-2016 09:27 AM
